Navigation & Audio Satellite Navigation Problem - No GPS Signals Found!
Old Dec 1, 2003 | 09:06 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
On Friday, my '03 MCS developed a problem with the Navigation System. Somewhere south of Syracuse, NY, it stopped seeing any satellites. I went into the "hidden" mode by holding in the [MENU] button while in the Options screen. The system is definitely seeing the wheel speed, but is finding zero satellites. I have done the following:
Disconnect both battery cables from car and do a "cold boot" - no effect
Check for Nav fault codes and clear codes with our prototype BiM-COM software - no codes, and no effect
Re-install v.22 CD for 3/1-62 - no effect
Schedule appointment at Main Line MINI for next Wednesday - slight placebo effect
So, here are my questions:
Has this happened to anyone else, if so, what was the resolution? Thanks!
Old Jan 16, 2004 | 02:35 PM
andy@ross-tech.com
Update:
I dropped of my MCS yesterday and picked it up today from MINI of the Main Line in Philadelphia (Peter the Service Manager and his tech Paul did great work). My Nav is now working again, it appears that the Nav Computer fried itself and took out the antenna amplifier with it. I now have the following new (or almost-new) parts:
84-50-6-918-548 Antenna
65-50-1-504-068 Amplifier
65-90-0-151-517 RMFD Nav Computer
Everything works as normal, except:
1) Now I have the annoying nag screen that makes me agree to a disclaimer before every use of the Nav system. GRRRR! Peter indicated this is in the new firmware and cannot be changed. Interestingly, the version is now 3-1/63 (I had 3-1/62 previously).
2) I now have a choice for "EMERGENCY" on my main menu. Pressing this shows the current latitude and longitude and has the number for 911.
3) They flashed my DME from v.32 to v.36. I had no driveability issues previously and didn't want the update, but they said it was necessary for interaction with the new Nav update.
So, I'm happy that my Nav is working again, but am unhappy about the new nag screen and the unwanted DME update. Incidentally, I also requested they perform the rear strut bolt recall as per the letter I got in the mail, but according to the dealer's system, my car doesn't fall under the recall.
Old Jan 17, 2004 | 06:00 PM
mbabischkin's Avatar
mbabischkin
It's good that it tells you the number for 911, I hear that in times of stress people are dialing 191....
Old Mar 5, 2004 | 04:49 AM
Venti_Due's Avatar
Venti_Due
I was returning from a ski trip in Cortina, Italy and going through some very thick fog and the Nav system showed me in Austria somewhere and at about 60,000 feet. Didn't even feel the lack of oxygen!
Old Mar 5, 2004 | 07:14 AM
andy@ross-tech.com
That's the time to pull over and take a pic for posterity! Here's my MCS in Maine at 0 ft elevation (it really was only a couple feet above sea level):
Old Mar 5, 2004 | 07:33 AM
sambusik's Avatar
sambusik
I hate the emergency disclaimer, it's part of the nav software v18.2.
You'll notice that any BMW with a nav system also has that nag screen. And there's no way to turn it off... which sux.
Old Mar 5, 2004 | 10:44 AM
andy@ross-tech.com
I'm gonna try retro-grading my Nav to an earlier version to try to get rid of the nag screen.
Old Mar 5, 2004 | 02:47 PM
pocketrocketowner's Avatar
pocketrocketowner
>>Update:
Wheeeewww....had me worried there for awhile. Though you had turned left a tad early and left for Saturn' orbit where the system can't pick up the satellites.
Old Mar 5, 2004 | 02:54 PM
andy@ross-tech.com
I wonder if GPS units freak out if you use it outer space? If you only picked up 3 satellites, it may not know if you are above or below the satellites. :???:
Zettinger
Aug 25, 2015 04:04 PM
Shane Wendel
Aug 18, 2015 01:13 PM
Super Coop
Aug 17, 2015 05:09 PM
skippermini
Aug 13, 2015 06:13 AM
clintmeister
Aug 12, 2015 11:11 AM
