Vacuum Leak?
Old May 25, 2010 | 02:13 AM
malteseracer's Avatar
malteseracer
Vacuum Leak?
So my car has been stalling out once or more times when it has been sitting a while, I originally thought this was a cold start issue with the chain tentioner but that seems to just be a rattle, not stalling out. It throws a P0000 code to my SG2.
I'm thinking vacuum leak, but before I start going over everything what are some common places that you wouldnt normally look?
Old May 25, 2010 | 09:49 AM
countryboyshane's Avatar
countryboyshane
That doesn't seem like a valid OBDII code. Your scan gauge might be misreading it. Why not take it to the dealer and get it fixed for free if you're under warranty? If you've already made up your mind that you want to look for vacuum leaks on your own, start off with easy stuff like the PCV hose and brake booster line connections.
Old May 25, 2010 | 11:50 AM
malteseracer
Dealer is booked til early July, so I wanna take a stab at it while I wait. Checked everything normal and tightened down everything on the hoses.
P0000 is a valid code normally for cold start problems as far as I know. There is another code being thrown but I can't read it.
Old May 25, 2010 | 12:37 PM
schatzy62's Avatar
schatzy62
P0000 is a valid code.
P0000: No Self Diagnostic Failure Indicated.
It should clear itself after a few days.
Did you disconnect the battery for some reason. That is the most prevalent reason for this code as far as I know. It more or less means that the diagnostics did a check and found no errors. This is done each time the car computers get restarted after a battery disconnection.
Old May 25, 2010 | 01:47 PM
malteseracer
Maybe my problem is electrical then? Could be the famed 3rd coil maybe?
Old Jun 5, 2012 | 03:32 AM
wellzy's Avatar
wellzy
What was the out come of the codes you were throwing, my did the same thing p0000 and the other I can't read?
ian260
Mar 29, 2017 06:08 AM
Oct 1, 2015 12:13 PM
JAB 67
Sep 29, 2015 01:34 PM
donniedarko
Sep 29, 2015 01:16 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
