R50/53 How to check power steering fluid level?
Old May 24, 2010 | 05:01 PM
kellymac's Avatar
kellymac
Hi.
Is there a thread on this site that has step by step instructions on how check and add power steering fluid to a 2004 mini? Also, what kind of power steering fluid I need?
Thanks.
Old May 24, 2010 | 05:20 PM
wrh3's Avatar
wrh3
Unscrew the cap on the power steering fluid reservoir (located to the right of the coolant reservoir) and it should be between the two lines on the stick.
Pentosin CHF 11S (this should also be noted on the top of the power steering fluid reservoir cap) is the ONLY fluid for the Mini electric power steering pump, available at your local NAPA for $22 OTD.
Old May 24, 2010 | 05:28 PM
kellymac's Avatar
kellymac
Thanks Bill.
Does it matter if the car has been running or if the engine is cool?
Old May 24, 2010 | 05:33 PM
ZippyNH's Avatar
ZippyNH
Car off....the stick may have hot and cold max/min lines....
Old May 24, 2010 | 05:47 PM
wrh3's Avatar
wrh3
I usually check mine warm, let the car sit for a half hour or so with the hood up and check it. Checking it cold may read a little low, kind of uncool for them to have excluded this basic check from the owners manual. I think the only requirements for the check is engine off and wheels straight, maybe not a big difference between cold and hot checks, we only have one set of lines and I am not sure what the Mini engineers intended since they didn't give us any info
Etrain
16
Aug 5, 2024 04:37 AM
rob&JCW
Feb 13, 2023 07:03 PM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
