R50/53 R53 fog lamp replacement/need help
Old May 21, 2010 | 10:55 PM
Fred's S Works's Avatar
Fred's S Works
I need to replace the passenger side fog lamp in the front bumper of my '03 S. Do I need to remove the bumper to get to it? Or can I get to it from underneath/above?
Thanks.
Old May 22, 2010 | 05:51 AM
Crashton's Avatar
Crashton
Pull the passenger side wheel off first. Then you can pull some of the fasteners from the fender liner & access the fog light by pulling the liner back or remove it completely. You do not need to remove the bumper cover. It is not too tough of a job.
You might want to buy some headlight film & install it on your lights. My lights are intact because of it. I bought mine from Outmotoring.
http://www.outmotoring.com/mini-coop...er_s_exterior/
Old May 22, 2010 | 06:29 AM
tlr1000's Avatar
tlr1000
Should be 4 fasteners IIRC. These plastic fasteners have philips heads that do get stripped and may need to be replaced if that is the case.
Old May 24, 2010 | 07:01 AM
JumpingJackFlash's Avatar
JumpingJackFlash
A technique for the plastic fasteners is to use a flathead screwdriver to pry at the edge while slowly twisting with a phillips head in the center. This will help keep from stripping them.
Old May 24, 2010 | 10:05 AM
tlr1000's Avatar
tlr1000
Great tip JJF. Unfortunately, the previous owner (or more likely the dealer) didn't do that on my car
Old May 24, 2010 | 12:40 PM
JumpingJackFlash
Looks like the part number for replacements is 07 14 7 146 367. They're listed at $0.50 per pair. See if you can get some at the dealership or other Euro parts store near you.
Old May 24, 2010 | 12:44 PM
tlr1000's Avatar
tlr1000
Thanks for taking the time to look up the part number!
Aug 19, 2015 12:51 PM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
