Help with missing items in engine bay
Old May 15, 2010 | 08:43 PM
itchynscratchy's Avatar
itchynscratchy
Need help from you guys. I had body work done on my car recently due to an accident that occurred last yr. When i checked the engine bay, there were components that were not replaced but i don't know what they're of or for and i was also unable to find the missing pieces using realoem.com. The area is around the driver side rails or below the intake pipe. Here are the poor quality pics using my blackberry.
Thanks in advance
Old May 16, 2010 | 12:30 AM
rkw's Avatar
rkw
There are pics of engine bays in the following threads. Perhaps you could point out what you think is missing:
https://www.northamericanmotoring.co...-pictures.html
https://www.northamericanmotoring.co...-dress-up.html
Old May 16, 2010 | 04:26 AM
HRM's Avatar
HRM
I'm pretty sure he is talking ot the pressure hoses that just end in midair. They look like part of the A/C system...maybe a evaporator or just the fill for the high and low side missing the caps. I am not familiar with the layout of the engine, but just using a total guess based on my limited experience.
Old May 16, 2010 | 05:48 AM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
The only things missing are the black caps. Part # 64538390633
Those are the lines for filling the AC system.
Old May 16, 2010 | 07:12 AM
moreorless's Avatar
moreorless
Thanks in advance
In the below image you can clearly see the missing black caps......
[IMG]file:///Users/lesrice/Library/Caches/TemporaryItems/moz-screenshot.png[/IMG]
Old May 16, 2010 | 03:08 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by SNEEEZY - Erika
The only things missing are the black caps. Part # 64538390633 Those are the lines for filling the AC system.
That is all that I can see that is missing as well. Everything else seems to be there.
Rich
Old May 16, 2010 | 03:40 PM
itchynscratchy
RKW, thanks for the links.
Aside from the caps, this is the item i'm missing and mainly concerned about:
Old May 16, 2010 | 03:45 PM
miniconcarne's Avatar
miniconcarne
Old May 16, 2010 | 03:48 PM
itchynscratchy
Originally Posted by miniconcarne
Thanks. Looks like i'm missing parts to the JCW air intake.
Since i no longer use the JCW airbox, does that mean those parts are irrelevant & no longer necessary?
Old May 16, 2010 | 06:56 PM
moreorless's Avatar
moreorless
Probably so as you now have a Cold Air Intake which pulls the air in via the cowl vent.
Old May 24, 2010 | 04:24 PM
midwestAce's Avatar
midwestAce
the part you're missing feeds air from the front into the aibox. You have no hookup for it on your CAI and would not be able to use it.
Old May 24, 2010 | 04:42 PM
miniconcarne
Bottom of the box (#1) should still be there. Making fresh air intake (#18 & #12) applicable.
Old May 25, 2010 | 06:15 PM
earlrabbit's Avatar
earlrabbit
You also seem to be missing the metal bracket that holds the electrical connections for the radiator fan. The same bolt that secures the air conditioner filler tubes (mentioned in posts 3 & 4) also goes thru this bracket. I'm not seeing those electrical connections so they must have routed them differently.
Kimolaoha
Jul 5, 2023 01:04 PM
blackie
Jan 18, 2017 09:57 PM
blackie
Jan 18, 2017 09:56 PM
makg
Aug 21, 2015 02:49 AM
chicohuahua
22
Aug 20, 2015 11:17 AM
