R50/53 transmission flush or drain and fill?
ok so many have opinions about should you flush or should you just dump and refill, my 04 MCS has 45K on it and i thought it might be a good time to change the fluid, i have heard horror stories about trans flushing, should i just dump the old and fill with new? looking for thoughts! thank you!
Morning guys,i've found it easy to change out the tranny fliud every
25k, may sound excessive but it works for me.i've been using redline
mt90. if your worried about metal being moved thru your tranny check
out MossMini's web site for a magnetic drain plug hope this helps.a
straight drain and fill should work just fine. so far so good with 93k
on the clock
on the clock
Actually had to do this not too long ago... mine's an '03 R50. stick.
ended up getting MTF-90 from the dealership down here in FL.. (bring your own CLEAN bottle to pick it up with, since they only sell it in bulk, here anyway)
The guy @ the parts counter told me that "technically" it's a lifetime fluid and shouldn't need to be replaced. i had to since when i was changing my clutch i made the mistake of not retaining the old stuff.
Given the option in the future, i'll drain, strain and reuse. and will DEFINITELY put in a magnetic plug
I changed the clutch @ around 113k miles.. hadn't EVER done anything with the MTF prior to that and never had any problems..
Any fluid that is lifetime is lifetime of the warranty.....if you have any doubts take a sample and send it to Blackstone Labs for analysis, you'll be glad you change it every 25-30k miles
Fluid is cheap, transmissions not so much.
Changed the fluid recently on our 6 speed manual at 23K with BMW/Mini spec fluid for our model. Had read several threads stating the whys and wherefores and many stated that there was an improvement in the smoothness or ease of shifting after a fluid change. I was a bit skeptical---but it's true. The improvement in the shifting smoothness is not gargantuan but noticeable. So it was a worthwhile endeavor for us and the transmission. FWIW.
The dealer is 3 hours away so I had the service done at Bavarian Auto in Wichita. They had to order the fluid from their BMW vendor-I don't know if it was from the dealer. Their service was very reasonable and quick. I forgot to mention that shifting into first gear is much smoother and easier since the fluid change.
Would you mind letting me know (either here or in PM if you prefer) how much the trans. drain/fill service was at Bavarian here in Wichita? I've got 80k on my '04 S and have been thinking of having this done. Bavarian has done service for me before and I like them a lot. The job is much easier to do on a lift which I don't have, plus I checked and my drain & fill plugs are very tight so I think I'll just have this done at the shop.
Accessory Products
Sep 11, 2015 08:01 AM
Sep 11, 2015 08:00 AM
