R50/53 Has anyone changed the air filter element lately ?
Old May 3, 2010 | 10:53 PM
MiniKar's Avatar
MiniKar
I have an 06 Mini S with 19 K miles. ( I only bought it last month )
I thought it might be a good idea to check the air filter since the car is
4 years old.
Wow, what a mess inside the air box ! Leaves, Sand, Hair, Etc.
Just glad I took a look; the filter looked like it had 50 K miles on it ......
Has anyone else found that this is a common thing with the stock
Mini S intake air box ??? Maybe it needs to be checked more often !
Old May 4, 2010 | 05:30 AM
Herleman's Avatar
Herleman
Mine is ugly @ 10K miles. I vacuumed it, and I'm ordering a K&N. (So its not just limited to the "S" model. If you wait for the Mini to do it at service time, the little car will be strangling itself.)
Old May 4, 2010 | 06:37 AM
ZippyNH's Avatar
ZippyNH
They can get pretty nasty pretty quick...our local mini guy has found a few mice nests in low milage cars to from when they sit...
Old May 4, 2010 | 06:56 AM
DAVESTER's Avatar
DAVESTER
While your at it, why not change your cabin air filter? Here's where I ordered mine---
http://www.atozautolights.com/2004-MINI-COOPER.html
Old May 4, 2010 | 08:46 AM
MiniKar's Avatar
MiniKar
I did that one already with a few problems. Now that I have done it once I know that the cover is not that easy to get off. Getting the cabin filter installed was easy compared to getting that cover off. Maybe smaller people with smaller fingers can get to all the MINI service items much easier than us with large hands and bodies ? ? ?
Old May 4, 2010 | 09:46 AM
Martin Brenneke's Avatar
Martin Brenneke
Had a dirty ITG filter and a loose belt and it threw code P0107. Cleaned filter and changed belt. No codes from then on.
Old May 4, 2010 | 01:19 PM
MiniKar's Avatar
MiniKar
I am going to try some 1/4" mesh over the front inlet to cut down on odd things getting into the airbox.
Hope it works !
Old May 4, 2010 | 05:38 PM
erickvonzipper's Avatar
erickvonzipper
If you replace your stock air box with a pod filter, you will not have those kinds of problems. Its easier to see when a pod needs cleaning.
silence2-38554
98
Sep 21, 2016 02:52 PM
theblackfalcon
Aug 26, 2015 09:18 AM
Beau B
12
Aug 24, 2015 01:50 PM
polotska
Aug 23, 2015 09:10 AM
Aug 21, 2015 08:44 AM
