Here we go agaaaaain.....
Spent the weekend at Roebling Road, GA. Had an absolute blast (as usual) I love that track and this time was no exception.
Unfortunately, I had an issue again with the bolts (studs) backing out of the turbo and leaving a gap between the converter and turbo thus allowing heat to escape and melt my valvecover.
This is the third time I'm going to replace the valvecover. The first time the nuts backed off. I thought it was just a one time mishap and didn't think much of it. (perhaps the bolts weren't tightened enough)
The second time, I double-nutted the studs and welded a bracket connecting the downpipe to the engine just like the factory.
This weekend, I noticed after a session that the valvecover was starting to melt. It was nothing, just a start.
I took the heatshield off, tightened up the nuts and drove to a parts store. Three hours later in the heat, I managed to replace all three studs and buy "exhaust" nuts (they're crimped on the inside in 3 spots)
I thought all was well and today after the second session, this is what I saw under the hood.
Honestly, I'm not sure why this keeps happening but rather than screw around with it, I'm putting the exhaust back to stock and see if it continues to happen.
There are tons of people on here with an Exhaust Depot converter and no problems. I'm sure it has something to do with tension on it from the rest of the custom exhaust.
On the bright side, Jan's tune KICKS AZZ... I pulled on SO MANY cars this weekend, I was absolutely blown away. Porsches, Mustangs alike saw my taillights this weekend and in the corners, forget it, sooner or later, they had to give me the point by.
Obviously there were many cars that would leave me sitting still (ie. Corvettes, 400+ HP porsches, S2000 with V8, etc, etc) but my point is, Jan's tune surprised A LOT OF PEOPLE!!!
Car ran flawless minus the melted valve cover. I'll fix it in the next few days and he'll be ready for the track soon enough.
I wanted to say THANK YOU to fellow member, Gordon (phlash) for his kindness, words of wisdom, use of his tools and most importantly, getting to ride in his mini on the track REALLY, I mean REALLY made my lines better.
If any of you are even thinking of going to a DE track event, I only hope you get lucky enough to have Gordon as an instructor.
Mark
Mark
Sounds like (sans melting) you had a blast. Did that track a couple years ago for a P-car event, had an absolutely phenomenal time. Was with a very well known Porsche instructor, and in his 944 Turbo, I was blowing by 997 Turbos by the second heat.
Good luck with the issues.
Hey, saw you on Indep a couple weeks ago, I was heading into town from your parts, and saw you a few yards ahead, but had to make a left on Sardis North.
Car looked gooooooooooood.
Mark
I'm trying to make the VIR trip still.
Mark
Well, as embarassed as I am to say this... it appears that I may have caused this last entanglement with my downpipe.
Reason being was the last time I had to replace the valvecover, I made a brace to keep the downpipe from vibrating. I welded a brace to the downpipe and bolted it to the engine much like the factory does.
Well... apparently I forgot to put the nut on the bracket that bolts to the engine. There is a stud there but no nut holding it on.
Point is, without that brace being secured to the engine, it was like not having a brace at all.
The fix? Obviously I'm going to have to buy another 400 valvecover. (300 cover and 100 trim piece)
Secure a nut onto the stud that is already there...DUH!
Last but not least, I'm making another brace and welding a second one to the exhaust to ensure this puppy never moves again.
On the downside, as I undid the nuts, the stud broke off in the turbo.
Guess I know what I'll be doing the rest of the day....lol.
Mark
Mark
oh man that is horrible! But hey, I guess the silver lining is you are familiar with the changes that need to be made? lol. At least it was detremental to your car, that would have been a big bummer.
my ALTA hasnt done this...although Im switching catless in a day so I need to make sure I secure this properly!
Mark
Thanks Mark. That track is my second favorite place to run......I cut my teeth there many, many moons ago. I was great having you in the right seat and I'm thrilled it helped you and helped you make your point with your instructor. The car looks great.....you done a really nice job with it....I'm bummed that the issue reared it's ugly head again before I had the chance to drive it....there will be other opportunities.
I was great seeing you again. Glad you hopefully found the issue. It's great to see the attitude and tenacity you have concerning all of it.
Thanks for the kind words....
Mark
Mark
Maybe you put the nut on but it vibrated off, or if you used a nylock nut and the heat from the turbo could have melted the locking device out of the nut. Even locktite can be effected by extreme heat, best bet is a stainless steel nut that has a crimped type lock.
Mark,
The only reason I didn't install SS is because I came across the missing nut on the bottom bracket.
Not only did I replace the studs, I installed new double nuts, replaced the missing nut on the brace, welded ANOTHER brace on to the converter and then wired tied the nuts on top...lol.
Anyway, we'll see... I'll try this and if it doesn't work, I'll either try SS or go back to stock.
Mark
Unfortunately with that idea, it's the stud that backs out sometimes. The last time I did this, I double-nutted it with exhaust nuts (the ones with the crimps) and they held.
Instead, the entire stud backed out
I think with both braces in the bottom, it should be fine... (of course, I thought I had it fixed twice before...
)We'll see....
Mark
