Slipping clutch
Old May 2, 2010 | 01:16 PM
ortuna's Avatar
ortuna
Slipping clutch
Soooooo... The clutch started slipping pretty badly last week. High revs little acceleration and sort of have to do a mini-rev dump to get the clutch to catch on 1st(I can also do a really slow let off the clutch press in the gas and it'll catch).
Anyways, this is 2003 MC Non-S. Need recommendations for good clutch/kit, and might as well get recommendations for flywheel too. I don't mind "performance", actually would be preferred but don't really care to have a 3 pound lighter setup for $900 extra or something like that.
Thanks!
Old May 2, 2010 | 02:28 PM
msmax96's Avatar
msmax96
this is the kit i used and love it over the dual mass original. engine runs better too!
http://cgi.ebay.com/ebaymotors/VALEO...item5d26be5da9
Old May 12, 2010 | 01:27 PM
ghurm001's Avatar
ghurm001
I used the valeo kit too, about 7k miles ago.. works fine. wasn't too expensive.. still uses that crappy plastic composite for the shoulder of the throw-out bearing, mine was SHREDDED (i posted some about my experience in doing this and the write-ups i used). i didn't change the flywheel while i was in there and i kind of regret it.
was the first time doing a clutch myself on ANY car.. it was all of the pain that i had heard it would be and then some. i bet now, though, i could have one done over a weekend, instead of the two weeks of working on it after work that it took me.
biggest pieces of advice:
1) get the stupid tool for popping the shifter cable from it's ball connections. it was $60, but the replacement cable i had to buy was around $130. EDIT: I actually was able to repair the gasket that holds the socket side of the ball joint together with some liquid gasket maker stuff from autozone, it worked like a charm, but i ended up replacing it anyway while i was in there putting in my short shifter.
2) watch out for the A/C line that the shifter arm moves over as you pull the trany away from teh engine.. mine got hooked on it and i almost busted a nut trying to hold that damn thing up while my father-in-law tried to move stuff around so it could be lowered.
good luck.
btw, i've got an '03 R50, too. turned over 120k miles this past weekend.
RobbyD
Jan 29, 2019 01:22 PM
eliseo1981
Nov 2, 2015 11:24 AM
vulkandino
Oct 31, 2015 08:29 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
