Hi from sunny England and quick tech question
Old Apr 29, 2010 | 01:31 PM
the colonel's Avatar
the colonel
Sorry to infiltrate your US site but struggling with my '02 Cooper. Trying to change seized rear caliper and cannot fathom how to disconnect the parking brake cable from the caliper.
Does anyone know whether there is a circlip or if they just seize and need a little persuasion ?
Thank you kindly for your help in advance and good to see there are so many enthusiasts across the pond.
Old Apr 29, 2010 | 01:55 PM
Martin Brenneke's Avatar
Martin Brenneke
Parking brake
If you have a Bently Manual section340-32 shows how. Otherwise you must disconnect the brake cable inside the car at the brake handle After that detach both cables from behind the brake handle by pulling cables up and outword. Then go back to brake caliper you should have enough slack to pull the cable off the caliper. I would suggest You Purchase a Bently Manual for the Mini as with it you can take the whole car apart and put it back together again.
Old Apr 29, 2010 | 02:06 PM
the colonel
Hi
Thanks Martin, yes, it must be time to invest in a manual.
I had disconnected the cable from the handle and have the slack, my problem is really 'unthreading' the cable from the old caliper, it just doesn't want to come out.
Thanks again, will hunt down a manual.
Old Apr 29, 2010 | 02:29 PM
Martin Brenneke
Parking brake
In the manual it shows a round actuating lever on the inside of the caliper. It says to pull cable housing down to free from caliper bracket after detaching cable from actuating lever. Arrow in picture shows moving cable towards inside of car. might help A little WD-40 on the cable at the end where it attaches to the caliper might help.
Old Apr 29, 2010 | 05:28 PM
Fatherdeth's Avatar
Fatherdeth
By the way, you didn't infiltrate this site. It's an international site!!! Welcome aboard!!
Old Apr 30, 2010 | 01:32 AM
the colonel
Thanks guys, really helpful and good to be aboard. Unfortunately seven years of our beautiful Brit climate has helped to seize the cable in the caliper - now where's that hammer.
Out of interest, are most minis in the US manuals (stick shift) or autos ?
The auto are rare over here.
Old Apr 30, 2010 | 11:02 AM
Cadenza's Avatar
Cadenza
There're more autos here... for any marque.
fastzombie
Sep 7, 2015 12:24 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
blackie
Aug 23, 2015 08:44 PM
PhoR53
Aug 21, 2015 05:10 PM
PhoenixR61
Aug 21, 2015 07:40 AM
