Interior/Exterior Removing all door trim
Old Apr 29, 2010 | 08:06 AM
tutono's Avatar
tutono
I have brushed aluminum trim pkg in a 06 sport conv that I want to paint but need to know how to remove all of the trim pieces. I have not sen any instructions any where on how to remove all these pieces so if someone can provide that it would be an immense help.
Old Apr 29, 2010 | 11:32 AM
rkw's Avatar
rkw
The entire door panel can be removed but the trim pieces are plastic welded to the panel. You can break the welds and re-glue the trim after painting. Look here for instructions on removing the door panel: http://www.mini2.com/forum/faq.php?f...aq_faq_removal (scroll down).
Old Apr 29, 2010 | 08:52 PM
03minime's Avatar
03minime
Yeah running into the same problem with my 03. I'm gonna mask the whole door panel off and paint them on the door panel. Or maybe I'll get some wraps from Lyle.
Old Apr 30, 2010 | 03:30 PM
TJWoodson1's Avatar
TJWoodson1
I had taken mine off about a year ago to have them painted. It is a plastic weld as mentioned above... I used a dremel with a cutting wheel and took them off. When it came time to put them back on, I lined it back up and melted the plastic back with a woodburner. It's worked fine.
mrjolliff
Oct 9, 2015 05:55 AM
missinmyjeep
Aug 22, 2015 07:13 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
