R50/53 Transmission Oil Question
Old Apr 21, 2010 | 04:34 PM
JAB 67's Avatar
JAB 67
2004 MCS w/ 6 spd manual, March 04 build date, no LSD. Time to change the transmission oil. What do members recommend? MTF-94? Redline? TIA.
Old Apr 21, 2010 | 08:55 PM
Some Guy's Avatar
Some Guy
Redline MTL seems to be highly recommended. I am using royal purple Synchromax which also is working well. I chose royal purple mostly because I could go out and get it at NAPA, whereas I never see Redline in stores.
Old Apr 22, 2010 | 02:16 PM
martinb's Avatar
martinb
6 speed Getrag GS6-85 up to 7/2004: MTF-94
6 speed Getrag GS6-85 from 7/2004: MTF-LT-36 speed Getrag GS6-85 with limited slip from 1/2005: MTF-94
6 speed Getrag GS6-85, GS6-53 BG/DG from 9/2006: MTF-LT-4
And if you have a limited slip, use MTF-94 regardless. There was a service bulletin a while back where people with LSD were complaining about noises in their LSD. Apparently, the MTF-LT fluids which some had were too slippery and causing the LSD to not work properly. Switching to the MTF-94 solves it.
Of course, if you're out of warranty, you can try something else. Like one of Redline or Amsoil's products. Both are excellent and almost impossible to beat.
Old Apr 23, 2010 | 02:17 PM
JAB 67's Avatar
JAB 67
My Mini dealer wants $32 per quart for the oil; can this be even remotely reasonable?
Old Apr 23, 2010 | 02:21 PM
slinger688's Avatar
slinger688
Manual or automatic?
If you have a manual, you could possibly use Redline MTL or D4 ATF.
Old Apr 23, 2010 | 03:08 PM
JAB 67's Avatar
JAB 67
See my first post. Manual, non-LSD.
Old Apr 23, 2010 | 03:12 PM
slinger688's Avatar
slinger688
If it is 4 season car, then I would think the Redline D4 ATF will be quite reasonable. Redline MTL is a little thicker so will have a harder shift during winter cold weather.
Old Apr 23, 2010 | 03:16 PM
martinb's Avatar
martinb
The lifetime lubes from BMW/Mini are very expensive. However, I do not think any lube is lifetime. That's BS. If you're Mini is still under warranty, use the factory stuff. If it's out of warranty, go with Redline's recommendation.
silence2-38554
Nov 12, 2015 09:39 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
Kahnfucious
Aug 15, 2015 08:43 PM
