Losing power, any ideas?
Old Apr 19, 2010 | 06:17 PM
buddy lee's Avatar
buddy lee
Started a few weeks ago. At idle (red traffic lights) with the AC on car would lose power for a split second and then come right back on. This means the radio would reboot, the lights on the dash would come on etc. The whole time this was going on though the engine would still be running.
Fast forward to tonight. Come around the corner (coasting) to pull into the driveway and it happens again, comes back on and then immediately EVERYTHING shuts off including the engine. I coast into the driveway, turn the ignition off and start the car back up. It starts up fine and I sit there for a minute and nothing happens.
Any ideas? Alternator? I wouldn't think battery because the car starts quickly every time. Any other ideas? I'm going to take the car in because I'm scared s--tless to drive it, but I wanted to see if I could get a ballpark idea of what the problem could be.
PS- when I bought it used in 06 I bought a warranty (the best one they offered) through Mercury. Anyone have any experience with them?
Old Apr 20, 2010 | 05:52 AM
buddy lee's Avatar
buddy lee
Mini's going in today for service, fingers crossed, will update thread later.
Old Apr 21, 2010 | 09:44 AM
buddy lee's Avatar
buddy lee
hahahahaha so far they can't re-create the problem! SHOCKED
Ugh.
Old Apr 21, 2010 | 11:04 AM
ZippyNH's Avatar
ZippyNH
What kind year is it? "S" non S?
More info is always better.....where are you....climate, etc....
Sounds a bit like a loose connection somewhere....I guess they didn't ell you if you got any codes?
It is very reminiscent of what cars once did with some water in the gas...but these days with all the ethanol in fuel, that is pretty rare now (the ethanol tends to absorb the moisture, allowing it to burn, in the same way methanol/iIsopropyl as used as dry-gas).
Old Apr 21, 2010 | 11:17 AM
Spooled's Avatar
Spooled
If everything shuts off including the radio, and your key is still in the ON position, it's gotta be electrical. Most likely a loose ground somewhere.
Old Apr 23, 2010 | 08:20 AM
JumpingJackFlash's Avatar
JumpingJackFlash
Oddball electrical issues are usually the result of a failing battery. More than likely, one of the cells has gone bad. Search the forum and I'm sure you will find several similar references. Easiest way to find out is to test it for amp charge.
Mini'mon
Aug 26, 2015 01:02 PM
Super Coop
Aug 17, 2015 05:09 PM
minipopkart
Aug 13, 2015 05:22 AM
wind715
Aug 11, 2015 07:56 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
