Crown Spoke owners...I have a question?
Old Apr 18, 2010 | 06:21 PM
///Mflossin's Avatar
///Mflossin
Before I attempt to take my wheels off, what do you use to remove the center cap? It appears that a flat blade screwdriver should fit into the slot but I want to make sure that there isn't a special tool that is used. Also, before I potentially damage them, is there a specific motion used to remove/disengage? Thanks in advance!
Old Apr 18, 2010 | 06:36 PM
slinger688's Avatar
slinger688
Use a long flat blade screwdriver. Push it slowly all the way in till it stops and then gently lift it till the hub caps come off. The hub caps will bend quite a bit but they will not break.
Sometimes I use two flat blade screw drivers, one to pull up the hub cap, the other to provide more leverage a few inches away from the first one.
Old Apr 18, 2010 | 06:51 PM
jcauseyfd's Avatar
jcauseyfd
If they are like the caps on my s-winders, the screwdriver that comes with your jack fits the slot perfectly for popping the cap off.
Old Apr 19, 2010 | 06:11 AM
///Mflossin
Thanks guys!
Colt45Magnus
Aug 27, 2024 05:03 AM
donniedarko
Oct 21, 2015 01:15 PM
Sep 11, 2015 01:15 PM
Manny_cooper
Sep 3, 2015 05:48 AM
broncobuddha
Sep 1, 2015 06:32 PM
