things my clubman have so far.
Old Apr 15, 2010 | 02:06 PM
supereek's Avatar
supereek
I just got my clubman back from a dealer. I want to share my problems.
I have gotten pretty much everything discussed in this section.
Here is a history of my clubman..
I purchased clubman S in July 2008 after long waiting.
1. Aug - 2008: DIY oil change at 1570
2. Dec - 2008 : Another DIY oil change at 8778
3. April - 2009 : passenger side window dipping shows up
4. May - 2009 : Check engine light on(cylinder misfire code)
5. May - 2009 : 1st oil change by mini (mileage 17988)
dealer reprogrammed passenger window
6. Sep - 2009 : DIY oil change at 24094
7. Sep - 2009 : CEL - cylinder misfire
dealer checked coil and spark plug
faulty thermostat - replaced
readjust passenger window again
8. Nov - 2009 : CEL on again (another cylinder misfire)
-replace high pressure fuel pump due to cold start
( I felt little hesitation when I started on engine)
- finally replace control module for passenger window..
9. Nov - 2009 : clubman got rear ended during parking overnight.
The other party's insurance replace the rear bumper..
10. Dec - 2009 : 30k service at dealer (?)
nothing but reset service status.. ( )
11. Feb -2010: Front brake pad warning @32367
- dealer replaced front brake pad but keep the rotor.
- passenger side still plate loose and jammed once - replaced..
- report to dealer that one side barn door is sticking out (?)
- at dealer shop, I notice that a gap in the pillar is exceptionally large ..
12. Mar 2010 dealer readjust both (barn door and pillar) after they showed them to a tech from MINI-usa and got approval from Mini USA.
13. Apr 2010 - Flat tire on highway
14. Apr 2010 - CEL ON and OFF several times (cylinder misfire)
Finally it checked by a dealer and they performed induction and fuel system cleaning..---> probably famous carbon-buildup thingy..
Is there anything else discussed in this forum and not included in history :(?
keyword: window malfunction, faulty thermostat, HPFP, Carbon-buildup, flat tire, accident..
I will see I can keep up with this maintenance.. so Sad..
Old Apr 23, 2010 | 06:10 AM
MrMatt's Avatar
MrMatt
I have also had P0300 and P0301 code in my clubman S intermittently. Did the fuel system cleaning fix it? My dealer also changed the spark plugs and it still happens.
Other problems I am having are:
-rumble/knocking from rear suspension going over bumps or rough road (dealer replaced sway bar bushings -- no change)
-various interior vibration noises - one from the plastic around the map lights another from the passenger side sun visor.
-driver side window sometimes slides back down after going all the way up (as if it is detecting a caught finger or something)
Old Jun 7, 2010 | 10:30 PM
richtgrlily's Avatar
richtgrlily
Honestly, my MCS has all the same problems. Do you have any modifications done to your car?
Old Jun 8, 2010 | 06:46 AM
supereek's Avatar
supereek
NO, no modification.
By the way, the tensioner and chain was replaced last month too. One morning the whole car was shaken and things got replaced.. I hope no more visit to the dealer.
Thanks,
matthewbrakeii
May 13, 2021 08:39 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
Aug 19, 2015 12:51 PM
Accessory Products
Aug 11, 2015 12:37 PM
Aug 11, 2015 12:34 PM
