Engine Buzz??
Old Apr 14, 2010 | 06:16 AM
R56Convert's Avatar
R56Convert
Engine Buzz??
Quick question to see if any one else has had this situation.
I have 1400 miles on the new S. When I accelerate hard to above 4500 rpm in gears 2-4 and then let off the gas there is a very loud buzz (sounds like a bunch of pissed off bees) that is much different from the engine noise itself. Heat shield loose ??? The noise doesnt seem to be present when I do the same thing below 4500 rpm, which is throwing me a little bit......
I have an appointment with the SA to take a ride this Saturday but figured I would bounce it off the forum to see if anyone has any ideas.
Other then that love the car!!
Old Apr 14, 2010 | 06:20 AM
malteseracer's Avatar
malteseracer
Not to say that you don't have a real problem because that is quite possible, but these cars are buzzy, vibration filled, noisy cars. Everything buzzes and makes noise, the motor is loud, etc. Its just how nit is and it adds to the personality of the car.
Old Apr 14, 2010 | 07:02 AM
R56Convert's Avatar
R56Convert
Thanks Malteseracer,
This is my first MINI and thats kinda what I was hoping.... but just wanted to be sure.
Old Apr 14, 2010 | 07:28 AM
malteseracer
Still get it checked out but rattles are something you need to get used to. Ur a VW guy I see, which in my experience are ver solidly built so don't sweat it the same.
Old Apr 14, 2010 | 08:53 AM
MBnAZ's Avatar
MBnAZ
I had something similar in my MCsa at just over 3K rpm on hard acceleration. Took it in, and the dealer diagnosed it as "harmonic noise maker faultily attached to bulkhead" and noted that they repaired it.
No more buzzing sound.
Good luck!
Old Apr 14, 2010 | 09:13 AM
R56Convert's Avatar
R56Convert
Thanks MBnAZ,
Good to know.
Old Apr 21, 2010 | 01:50 PM
RilianMini's Avatar
RilianMini
I have been searching through the forums, and all I can find is cold start chatter/ noise issues..
It appears I finally found someone with the same problem I seem to be having!!
However, I have a 2007 MCS with 45k miles........ and I didn't renew my service contract after 36k miles...
What have you found out about this issue??? Is it something I will have to pay a ton to get fixed??
Thanks!
Old Apr 21, 2010 | 07:56 PM
R56Convert's Avatar
R56Convert
Hey RilianMini,
I took a ride with two SA's, both mini owners, over the weekend. I was able to duplicate the noise. However they did say that it was a normal mini sound, and there was nothing to do to fix it. I figure I'll wait till a mini event and give one of the local long time mini owners a ride just to be sure.
Sorry not much more help. I'll post back if I hear something else.
Old Apr 21, 2010 | 08:04 PM
gawannamini's Avatar
gawannamini
Turbocharged MINIs have a blow off valve (most turbos have them). It makes a buzz or hissing sound immediately after you lift off the accelerator - particularly if you are accelerating a tad aggressively. You can really hear it in a convertible with the top down. It is hard to hear in a MINI hatchback.
If the turbo didn't have this as soon as you let off of the throttle the air leaving the turbo would have no place to go and the turbo would take longer to spool up once you have shifted and are going for the next gear.
If it is the blow off valve the buzzing only lasts a second or so.
Happy Motoring
Old Apr 22, 2010 | 06:29 PM
turbodeez's Avatar
turbodeez
https://www.northamericanmotoring.co...amplifier.html
might want to check out that thread, I am pretty sure that both of our cars are making the same noise... and it is only under higher boost levels
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
