Suspension Stock tire size rub on M7 coilovers
Old Apr 7, 2010 | 06:27 PM
laxpimp6903's Avatar
laxpimp6903
ive got stock size tires, 205/45/17 and i FINALLY just got my M7 coilovers installed only to find out that my wheel rub on the large heavy duty shock body.
Has this happened to anyone else, and do i simply need some small wheel spacers?
Old Apr 7, 2010 | 06:35 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Common problem when it comes to high, conservative offset wheels when used with coilovers. Spacers or lower offset wheels will solve the problem.
Old Apr 7, 2010 | 07:00 PM
laxpimp6903
Ight. That's what I figured. I'm not too worried about it accept that I have work at noon tomorrow and have to try and find a set before work.
Old Apr 7, 2010 | 07:10 PM
laxpimp6903
I'm not sure what the offset on ny wheels is but they are oem.
Old Apr 7, 2010 | 08:12 PM
Rally@StanceDesign
Good luck, thought that seems like it's gonna be tough unless you have a good shop around. There are some online shops that can get them to you pretty quickly if you can't find them locally.
Don't drive around with them rubbing, you can easily rub through the tire and leave you with two flats and a dangerous situation.
Kimolaoha
Dec 5, 2020 09:32 PM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
kazyn
Oct 25, 2019 02:34 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
