need some help on which tires to buy for my rims.
im planning purchacing these ALTA rims, http://www.outmotoring.com/mini-coop...279_Wheel.html
now i need help on chosing the right tire for them. i really dont know much about tires and would be thankful for any advice and help. Which tire size would be better? 215/45 R17 or 205/45 R17.
Johnny is right, there are probably more 215's than 205's now. On a 7.5" rim, I'd be going with 215/45/17. I just put new rims (17 x 7) and tires (215/45/17) on my car. I like the look and feel of the 215's much better, jmo.
another question, could somebody explain the offset of tires? what is it? also would there be any problems with the rims i want to buy when i go and put them on my R53?
For a 17x7.5 with a 35 offset I would play it safe and definetly get a 215/40-17 tire, just to make sure I don't rub outter edge.
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel, usually measured in millimeters.
Don't think Alta makes wheels, they maybe called just ALT.
L3Mix
Aug 26, 2015 07:00 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
