Drivetrain how to install sprint booster
Old Apr 1, 2010 | 02:41 PM
tikka1969's Avatar
tikka1969
yea the title is right.i have no idea how to get to the connector.i can see it and touch it but can not release the detent that holds the plug to the connector.every time i have to take a pannel or some trim piece off i end up breaking clips or somthing.so this time i will i will ask a stupid question and feel like a tool instead of breaking something again.so here we go.
how do you remove the cover assy to get to the plug location on the gas peddal for a 2003 mini s 4 spd?
i do see what looks like phillip screws on the side of the housing granted i have nothing that fits them (torx,phillips,allen,tamper proof torx ect.ect)and plus the stearing shaft blocks the top screw anyway.i am thinking it comes another way.
Old Apr 1, 2010 | 03:08 PM
Oxybluecoop's Avatar
Oxybluecoop
Try these instructions.accelerator pedal module.pdf
or these:http://www.sprintboostersales.com/in...2095_instr.pdf
Old Apr 1, 2010 | 04:12 PM
tikka1969's Avatar
tikka1969
thanks would have never figured that out.not sure if i should start another post for this but i am pretty sure you have the answer.is the statement below correct for resetting you service interval counter.i tried it but the counter changed from 7500mi to 15500mi?
[SIZE=2]Press and hold the trip odometer button.
Insert car key and turn it to the first position.
Watch for the word "RESET" to appear on the Odometer indicator.
Release the trip odometer button, then press & hold it again.
Wait for the "RESET" message to flash.
Release the button, and then press & release (once only)
The Service interval is now reset
[/SIZE]
gundesen
Nov 19, 2015 07:33 PM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
