MINI is cutting off when i start it up. i think its the fuel pump
Old Mar 31, 2010 | 09:44 PM
bills04mini's Avatar
bills04mini
Well today at lunchtime i was headed to school and my 04 MCS just randomly started sputtering and started to loose power. It randomly revved up to about 4000 rpm and then shut off. I started it back up and managed to baby it into a local barber shops parking lot. Now when I go to start it up, it starts fine, runs for about two seconds and cuts off. I think it might be the fuel pump, but has anybody had any similar problems or know anything else it might be? Any possibilities would help. Thanks!
Old Apr 2, 2010 | 03:22 PM
GumbyLara's Avatar
GumbyLara
I am having the same problem right now. My 03' MCS is in the shop. Thinking it's either a fuel pump or vacuum leak! Good luck, i'll let you know my outcome once my mechanic tells me this weekend!
Old Apr 8, 2010 | 11:50 AM
bills04mini
Anybody else have a clue what it might be?
Old Apr 8, 2010 | 12:17 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Mass Air Flow sensor, I think.
I'll check the receipts hat I had done I can't remember
Here's is my thread from what was happening to me.
https://www.northamericanmotoring.co...bd2-p1109.html
Old Apr 8, 2010 | 09:04 PM
bills04mini
Well I got a new fuel pump from the factory today and got it put in and everything is going fine so far. If anything else pops up, I'll be sure to post about it.
Old Apr 9, 2010 | 07:59 AM
JumpingJackFlash's Avatar
JumpingJackFlash
MINIs do not have a Mass Airflow Sensor. They are set up using Speed Density, which involves two MAP sensors.
Glad to hear it was the fuel pump and it's fixed.
Old Apr 10, 2010 | 06:05 PM
GumbyLara's Avatar
GumbyLara
Turns out my problem was my Expansion tank had a crack in it and ran my car out of coolant, and since the temperature sensor is in the top of the container, it wasn't reading my car was overheating. No idea, got a new tank, refilled it, also replaced the valve cover gasket and now my Mini is back in action!!
Old Sep 22, 2011 | 09:57 AM
tech8111's Avatar
tech8111
im confused, i own a shop at witch we make repairs to all cars trucks ect... work on many land rovers & minis . we have recently finished a restoration of a 52 riley. im currently working on a 08 mini cooper and it does have a mass air flow sensor , the terminology may be different how ever all three of the scan tools the we use show mass air info . this car also has three mass air flow codes , it stumbles during a cold start & stalls from time to time. a week ago the car was in our shop with miss fire codes for cylinders one and two in looking for the cause we found alot of carbon build up and did three back to back fuel system cleanings afterwords ran great
Old Sep 25, 2011 | 04:09 PM
msjulie33's Avatar
msjulie33
06 cooper coupe/08 cooper convertible had super charged engines but the 2nd gen had a turbo ... different engines
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
TunedGP
Oct 1, 2015 04:18 PM
bc219
Aug 10, 2015 11:22 AM
