No oil Mini
Old Mar 30, 2010 | 07:29 AM
abamca's Avatar
abamca
No oil Mini
My Mini met a universal ball joint from a truck laying in the freeway with no place to go. Shattered the oil pan, ran for three miles to get off and stopped. Will see if it survives.
Old Mar 30, 2010 | 07:38 AM
ofioliti's Avatar
ofioliti
Woah! The MINI ran for three miles with THAT hole?
Poor MINI. I'll cross my fingers for ya.
Old Mar 30, 2010 | 09:10 AM
JumpingJackFlash's Avatar
JumpingJackFlash
Wow!
Old Mar 30, 2010 | 09:30 AM
MINIdave's Avatar
MINIdave
You were being sarcastic, right? 3 miles at highway speeds with no oil pressure? It should be toast.
Good luck, but a new engine is probably in your future...
I'd be talking to your insurance company about a new engine, were it me, depending on the miles and condition of your car ....otherwise, it might be time for a new MINI.
Old Mar 30, 2010 | 10:37 AM
daflake's Avatar
daflake
Originally Posted by JumpingJackFlash
You should be fine. You only went three miles with lost oil/pressure. That's really not long enough to cause issues. There should have been enough oil lubrication between the crank and connecting rod bearings.
Yeah, nope..... What he should have done was pulled off to the side of the road and called a tow truck. Like he said above, I think a new engine is in his future.
Old Mar 30, 2010 | 10:59 AM
ZippyNH's Avatar
ZippyNH
+1
Even if it runs again....it will never be the same....should have coasted to the side of the road....and gotten a tow.....RED LIGHTS mean engine damage is occurring NOW...STOP ASAP.
It may run a while with a fresh oil and a new pan...but the bearings are likely scarred from overheating/oil starvation. Once that happen....it is only a matter of time!
Old Mar 30, 2010 | 11:15 AM
newbs49's Avatar
newbs49
Call you insurance company. You'll need a motor down the road for sure. Where are you located?
Good Luck
Old Mar 30, 2010 | 11:49 AM
ZippyNH's Avatar
ZippyNH
Sorry to see you first post is for such a crappy reason.
Welcome to NAM anyway, and good luck!!
Old Mar 30, 2010 | 02:09 PM
JumpingJackFlash
Keep us informed.
Old Mar 30, 2010 | 02:24 PM
daflake's Avatar
daflake
I'm not being sarcastic. Just because you have no oil pressure does not mean there is nothing there to lubricate the parts. Doesn't anyone recall those commercials where they drain out the oil and time how long it takes for the engine to sieze? Perhaps the side of the pan did not fall off right away.
Those commercials are designed to get you to buy the product and marketing groups will rig engines to run in that condition just to shoot the commercial. Trust me, I have a family in advertising.
Old Mar 30, 2010 | 02:45 PM
911Fan's Avatar
911Fan
...pull one or two crank main caps to check the bearings... That sort-of falls under acts of nature.
This is an extreme case of oil starvation. You'd have to check every lubricated surface for damage -- not just one or two main bearings.
I'd insist on a new engine from the insurance company.
And, no, it's not an "act of nature", which would give the insurance company an out -- it's damage resulting from debris on the roadway which should be covered.
Old Mar 30, 2010 | 02:59 PM
newbs49's Avatar
newbs49
+1
Old Mar 30, 2010 | 03:27 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Holy cow!
Wonder if one of these would have helped. I have been riding the fence on buying one since there seems to be more debris on the roads today more than ever.........
Best of luck in putting your MINI back on the road !
http://www.allminiparts.com/showAsse...mbly=100-063_1
Old Mar 30, 2010 | 03:34 PM
PenelopeG3's Avatar
PenelopeG3
Same thing happened to me in my e36 BMW on the Cross Bronx Xpressway. It also took out my fuel filter and my car stalled immediately so no internal damage.
Good luck to you. Your engine is probably shot. Hope you have full coverage on your insurance.
Old Mar 30, 2010 | 03:42 PM
rkw's Avatar
rkw
If the object wasn't moving, insurance may cover it but you will be at-fault in a collision claim.
Old Apr 28, 2010 | 08:32 AM
abamca's Avatar
abamca
No Oil Mini - Update
Settled with insurance - total loss, $15.3K, bought for savage $3K, repaired oilpan $1.2K, driving home today.
Old Apr 28, 2010 | 10:50 AM
thulchatt's Avatar
thulchatt
So you get 12,300 from the insurance and fix the car for 1,200?
Not bad deal. Yes it will have a salvage title but that sounds like a very good outcome for you.
Old Apr 28, 2010 | 06:34 PM
ZippyNH's Avatar
ZippyNH
Wow...a good used motor is only $5000 or so!!
Just transfer the reg to RI for one hour...then re-register it in your state...no junk title...some companys will even handle the transactions for you...will get you will have a clean no-junk title. Not a clean car-fax, but a clean title. It is very commonly used with restored cars that are frame off restorations that were junkyard finds....I think there is one other state that does the same thing....
Old May 5, 2010 | 11:32 AM
JumpingJackFlash
So, are you telling us the only needed repair was the oil pan?
Old May 5, 2010 | 12:12 PM
daflake's Avatar
daflake
For now.... There is no telling how long the engine will survive which is probably why the insurance company wrote it off.
Old May 5, 2010 | 12:50 PM
kb30's Avatar
kb30
wow, that took one hell of a hit...
Old May 5, 2010 | 01:07 PM
newbs49's Avatar
newbs49
Not a bad deal. Hope it stays alive for ya.
Old May 5, 2010 | 03:32 PM
Agarwaen's Avatar
Agarwaen
heh. pretty good trade off if you planned on keeping it until it was scrap. Save that left over cash until the engine goes, and drop a good on in. =) the car can have 2 lifetimes for the price of one!
Old May 5, 2010 | 06:30 PM
newbs49's Avatar
newbs49
+1
Old Jun 17, 2010 | 01:31 PM
abamca's Avatar
abamca
Car has survived 2 months and 1500 miles without any engine problems. Now time to think about replacing bent subframe, tires, alignment, etc. Probably about $2K.
