R50/53 Cooling Fan - How do I remove it?
Old Mar 29, 2010 | 02:54 PM
JAB 67's Avatar
JAB 67
Need help. I have the front end torn apart - bumper skin and reinforcement beam removed, modular front end (MFE) in full extension. How does the fan come out? From behind the surrounding structure (to which the radiator attaches) towards the engine, or must I remove the radiator then slip the fan assembly through the front?
Old Mar 29, 2010 | 04:09 PM
JohnnyVillan's Avatar
JohnnyVillan
You just need to loosen the top of the radiator so you can pull it forward and remove the upper radiator hose (be careful not to spill any coolant on your alternator cause it's right underneath.) The fan just slides out the top.
Old Mar 29, 2010 | 04:15 PM
JAB 67's Avatar
JAB 67
No way it can be done without removing the radiator hose?
Old Mar 29, 2010 | 04:28 PM
JohnnyVillan
Nope. I tried for hours. Just ball up a rag and cover your alternator and pull the hose off. Some coolant will come out but not alot. You might have to bleed the system when you re-install.
Old Mar 30, 2010 | 05:33 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Johnny is right on target. Have some items handy to support the front radiator assembly to keep it from pulling on the wiring connectors, you don't want to just let it hang there.
Here are some pics I took when replacing mine. Good time to inspect upper and lower hoses and thermostat housing for leaks. If you see white powdery residue that gasket may need to be replaced. There are updated gaskets for these which are supposed to last longer.
Kimolaoha
Jul 5, 2023 01:04 PM
alistaircookie
Oct 8, 2015 10:52 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
greekzilla
Aug 23, 2015 03:44 PM
Chippawaguy
Aug 19, 2015 10:59 AM
