Just rotated my tires myself for the first time -- do they need to be balanced, too?
Old Mar 29, 2010 | 01:20 PM
Headlands's Avatar
Headlands
They were already balanced by the shop that put the tires on in the first place, and since driving it after the rotation I did, I don't feel any vibrations or anything.
Some people say you need to rebalance after rotation, and some don't. It doesn't make sense to me that you would need to, though, since balancing is done off of the car itself, so theoretically once a tire is balanced it shouldn't need to be again unless something happens to shake it up like a huge hit or something. Am I right about this?
Old Mar 29, 2010 | 01:24 PM
ronnie948's Avatar
ronnie948
I don't think so if no wobble.
As you said, they were off the car when they were balanced so if you do not have a wobble you probably are just fine.
Old Mar 29, 2010 | 01:41 PM
iwashmycar's Avatar
iwashmycar
no, your fine. only if you start to feel something.
Old Mar 29, 2010 | 04:34 PM
veggivet's Avatar
veggivet
Does three no votes make it unanimous? No need to rebalance unless a wheel weight fell off during the rotation process, which isn't that likely.
Old Mar 29, 2010 | 05:25 PM
Crashton's Avatar
Crashton
If they were balanced when they came off they will be balanced when they go back on after rotation.
Old Mar 29, 2010 | 07:44 PM
Headlands's Avatar
Headlands
Thanks!
Old Mar 29, 2010 | 08:00 PM
gawannamini's Avatar
gawannamini
And to beat a dead horse since we are all in agreement we balance as tires wear to compensate for the inevitable uneven wear. Also if a tire is removed from the wheel it needs a rebalance as both wheel and tire have some imballance and we need to compensate after the tire is mounted.
If the tire is just moved around, the weights are still in place and the tire was running smoothly before you moved them to thier new position you are fine. No balance needed.
Headlines - did you determine that the tires are not unidirectional? Just curious...
Old Mar 29, 2010 | 11:31 PM
Headlands's Avatar
Headlands
Originally Posted by gawannamini
Headlands - did you determine that the tires are not unidirectional? Just curious...
Yes, I did. I was mistaking the Dunlop logo (which includes an arrow-like figure in it) for rotational arrows, since they are placed all along the top sidewall. Yep, it's a bit embarrassing!
Old Mar 30, 2010 | 06:20 AM
JumpingJackFlash's Avatar
JumpingJackFlash
Though I don't do this very much, it is recommended you get your tires rebalanced about every 5,000 miles, or whenever you do a realignment. If you bought your tires with a warranty, rebalancing should be included. Tire rotation should be done as often. If your tires are directional, it's recommended to just go front-back and not do the cross-rotation (which would require remounting/rebalancing all four tires).
Last edited by JumpingJackFlash; Mar 30, 2010 at 06:22 AM. Reason: Added rotation info
Old Mar 30, 2010 | 06:31 AM
freez3's Avatar
freez3
From: United States of America, Ohio, Stark County, Uniontown
[QUOTE=gawannamini;3017551]And to beat a dead horse since we are all in agreement we balance as tires wear to compensate for the inevitable uneven wear. Also if a tire is removed from the wheel it needs a rebalance as both wheel and tire have some imballance and we need to compensate after the tire is mounted.
Tire wear should not be "inevitable". If your car is properly aligned and you rotate your tires, they should wear evenly.
I'm about to replace the tires on my X3 that have over 50,000 miles and are all worn evenly.
Old Mar 30, 2010 | 06:37 AM
JumpingJackFlash
Yes, tires should wear evenly, but the MINI by design does not do that under normal driving conditions. Just look at it from behind; you can obviously see the two rear tires have an offset camber. This is done because MINIs are designed to do alot of "cornering," hence the love for twisties. Long drives on a straight highway will eventually cause the inner edge of the rear tires to wear down. You will definitely want to rotate tires as much as possible to prevent it all at once.
I don't care how much anyone here has tried. I really highly doubt one MINI owner has been able to get the rated tire life mileage. You already have the softer compound of "W" or "Y" rated tires working to your disadvantage. I typically get 25,000 miles out of 40,000 mile-rated performance tires. The MINI is a sports car. If you really want to try to get optimum mileage, get tires that have a treadware above 300 and are "S" or "T" rated (but you won't like them).
Old Mar 30, 2010 | 07:35 AM
jcauseyfd's Avatar
jcauseyfd
I got 40k miles out of my OE Goodyear Excellence RFTs. They have a treadwear rating of 240, but I'm not sure what kind of mileage that translates to. The wear was nice and even across the width of the tire.
Old Mar 30, 2010 | 08:16 AM
JumpingJackFlash
A treadwear of 100 is a baseline for a given tire type. Read more here: http://www.tirerack.com/tires/tirete....jsp?techid=48. The value has to be compared against other tires of the same type, which means don't compare "S" rate tires against "W" rated tires. Any ZR performance tire will be made of a softer compound to provide better road grip. This is the tradeoff and will definitely mean a lower tire life. It's actually almost comical these tires have a mileage rating.
Old Mar 30, 2010 | 01:22 PM
Crashton's Avatar
Crashton
Running over dead horses or even live ones can be very detrimental to tire balance & alignment.
Back on topic...
If one is running a lot of negative camber rotation will help. If you want the most out of the tires you can have them flipped on the rim to get the most out of them. Remember to rebalance!
Old Mar 30, 2010 | 02:34 PM
Ryephile's Avatar
Ryephile
The best way to unbalance them is to put them back on sloppily so they're not hub-centric. That doesn't mean the hub of the wheel is bad, just that they didn't align the wheel bolt chamfers within the wheel chamfers very well. Some cars are more sensitive than others, the MINI is one of the more sensitive out there, right there with the Miata and Elise. Maybe it's a 4x100 thing *shrug*
Old Mar 30, 2010 | 09:30 PM
Robin Casady's Avatar
Robin Casady
When tightening the lug bolts, do it in stages in an X pattern so they are all tightened as evenly as possible. I do it in about three stages, finger tight, snug, and torqued to 103 ft-lbs (R56).
Wheel hangers make rotation easier.
To the original question: Most shops balance wheels off the car, so which corner of the car it is on wont matter. Reblance if you feel vibration at 140 mph.
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
Dashdog
Aug 10, 2015 06:17 AM
