R50/53 Reminder to change your cabin air filter
Old Mar 27, 2010 | 05:18 AM
xman11's Avatar
xman11
Reminder to change your cabin air filter and then some
I bought my '02 mcs with 85k miles this week and decided to do a home service. This is basically an inspection 1 and 2 plus some very important fluid maintenance not covered by 1 and 2 such as bleeding clutch, brake, changing coolant, etc...
First thing I changed was the cabin air filter. Took about 15 minutes. Here's a pic of the old one. Yikes!
Also, the air filter was just as bad. The spark plugs (probably original) were not too shabby considering how many miles they weathered.
Attached Thumbnails Reminder to change your cabin air filter-cabinfilter.jpg   Reminder to change your cabin air filter-airfilter1.jpg   Reminder to change your cabin air filter-img_2293.jpg
Old Mar 27, 2010 | 06:34 AM
MendoMini's Avatar
MendoMini
Easy to do.....
Just did mine yesterday, same thing for me also.
Old Mar 27, 2010 | 05:24 PM
laxpimp6903's Avatar
laxpimp6903
i will have to check out the cabin filter. Could you post a quick DIY since i have no idea where it is in the car?
Old Mar 27, 2010 | 11:35 PM
xman11's Avatar
xman11
I followed the DIY shown here: http://www.geekshocker.com/Claire/maint/cabinFilter.php
Old Mar 28, 2010 | 07:30 AM
MendoMini's Avatar
MendoMini
Cabin Filter
I did a Youtube search found it there.
Old Jun 6, 2012 | 04:09 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Note that in this YouTube video it says the flow direction is UP. That is incorrect. The flow direction is DOWN and the filter has an arrow on it which suggests there is a top and a bottom and needs to be inserted in the correct direction.
The flow arrow needs to point down. It fits better that way as well. If you need proof of the flow direction just consider where all the dirt is. On the top.
Rich
Old Jun 6, 2012 | 04:29 PM
Gizmo's Avatar
Gizmo
Make sure you change out the FUEL filter too, it is under the rear seat.
Old Jun 6, 2012 | 10:31 PM
LittleWing's Avatar
LittleWing
Would this be covered under the Maintenance Warranty?
Old Jun 7, 2012 | 03:53 AM
Gizmo's Avatar
Gizmo
Yes I believe so.
Old Jun 7, 2012 | 07:38 AM
Rich.Wolfson
I think Mini says 2 years or 20,000 miles. I change mine every year. It is always filthy. And easy to do.
So, like oil, the Mini intervals for this filter are longer than, what I would consider, reasonable.
But yes, at least one change, possibly two under the maintenance warranty would be expected.
Rich
Old Jun 7, 2012 | 08:05 AM
LittleWing's Avatar
LittleWing
Originally Posted by JohnW94
Yes I believe so.
Rich
Thank you!
Old Jun 7, 2012 | 09:21 PM
Rich.Wolfson
Cabin Air Filter—Schematic
So after replacing my cabin air filter yesterday, which was filthy BTW, my air conditioning seems to be much more effective. I say that just to get all of you that have been putting off changing it, to do it now at the beginning of the A/C season.
But I also got to thinking which for me is always bad.
The air clearly comes from the top through the filter and into the cabin. Evidence of that is that the dirt is on the top. But if it blows in, where does the air come from? All the vents, of course, have air coming into the cabin as well as do the vents under the windshield and in the top of the dash.
So is the air going through the cabin air filter air that has gone through the heater or A/C? And when you have the A/C on recirculation, where does the air from the cabin go in?
In the old days it was easy. Everything went through the heater box where the A/C evaporator also resided. Then it was into the cabin cold or hot depending. But on our Minis......?
Am I missing something?
Rich
PS-There is no schematic in Bentleys or the Haynes manuals.
Old Nov 17, 2012 | 03:26 PM
Garconis's Avatar
Garconis
Rich
I was under the impression that the air comes out of the vents AFTER it has gone through the cabin air filter. There is air in the car by default, and that air is sucked from the ground up into the cabin air filter, and then it comes out through the various vents. Though I am probably wrong.
But there is a "filter" button on the A/C and Heat control, and I would assume that's what "activates" the air to be pulled back through the filter and into the vents again. But it would also make sense the other way too. So confused.
Old Nov 17, 2012 | 04:40 PM
ZippyNH's Avatar
ZippyNH
One reminder...
The filters are sold in 2 types...
A white, plain filter...
and a dark grey, light black one impregnated with Carbon one that absorbs odors for a few $ more.
Old Jun 5, 2013 | 12:45 PM
TGS's Avatar
TGS
I'm new to MINI and want to change my cabin air filter but wonder if it's worth it to buy the carbon ones.
What are some good, reliable places online to purchase these?
What is the average price you pay?
Old Jun 5, 2013 | 01:04 PM
Here are a selection of cabin filters , the carbon ones seem to be the most popular as they contain carbon to absorb odors. Like zippy said.
They all fit some just have different material for the frame. R50 R52 R53 models.
Undo the lid on the passenger side footwell, remove the old one out and slide the one in at an angle and will slide upward. Then close up the lid.
Cabin filter regular:
http://www.ecstuning.com/Search/SiteSearch/64311496710/
Cabin filter - Active Carbon
http://www.ecstuning.com/Search/SiteSearch/64319257505/
Old Jun 26, 2013 | 01:20 PM
TGS's Avatar
TGS
Thank you! I will check them out.
Old Jun 26, 2013 | 01:37 PM
You are welcome,
When you pull the old one out it can be pretty dirty if not changed for a while. Expect some dirt and leaves to get on the carpet. When you snap the lid back in can be a little tricky just push up the lid and press the tabs back in place.
Old Jun 28, 2013 | 12:11 PM
brody78's Avatar
brody78
Haha.... Yes take this advice, I broke one of mine being too impatient.
Old Jun 28, 2013 | 12:29 PM
You are welcome.
Taken them off many times to sore fingers. If you bust the clip in part of the tab on the lid side, front or the rear then you have to replace the lid. They snap in very tight.
#3 Cover For Microfilter Housing 64311497542
http://www.ecstuning.com/Search/SiteSearch/64311497542/
Old Jun 28, 2013 | 03:24 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We sell both the carbon and non carbon versions. I personally like the carbon even though they are a few bucks more as they smell better over time. We also recommend replacing them once a year.
I could take pics of some we've replaced but you might get sick. Especially if you're a smoker it will scare you to think of what your lungs look like if the filter looks as bad as many I've seen.
Old Jun 28, 2013 | 03:45 PM
Salbotehcow's Avatar
Salbotehcow
I got my car used with 30k on it, I was thinking the A/C felt weak coming out the vents yesterday. I guess its time to place an order at WMW, lets see what else can I talk myself into....
Old Jun 28, 2013 | 06:16 PM
mgrant's Avatar
mgrant
should be doing this next week when the parts arrive ... I to have noticed the lack of air coming out of the vents
Old Jun 29, 2013 | 02:24 PM
LittleJoe's Avatar
LittleJoe
My car had a bad smell. It finally occurred to me that I needed to replace my cabin air filter.
I did the job about 2 weeks ago. It made the smell almost go away completely and I get at least twice the airflow out my vents!
I bought my 2006 MCS with 99k miles on the clock. I'm guessing the cabin air filter had not been changed in at least 50k miles. It was completely clogged.
Old Jun 30, 2013 | 04:16 AM
04_Indi_Mini_S's Avatar
04_Indi_Mini_S
You are welcome,
Ha ha, when I did mine after buying the car I had acorn pieces, leaves, and clumps of what looked like... ah nevermind, it was DIRTY!
In addition to what has been posted here, I recomend taking a damp rag and wiping as far inside the filter housing as you can reach. I did this and the rag came out black and nasty.
This was my filter when I got the Mini(old one was carbon new one was non carbon but you can see all of the crud on it still):
And my brand new floor mats after pulling the filter out:
