Need proper pressure for My New tires
Old Mar 25, 2010 | 08:26 AM
seojea's Avatar
seojea
https://www.northamericanmotoring.co.../IMG_00813.jpg
I need a suggestion an what i pressure i should run on my new tires
205/40 r 17
the max psi on them is 40
Any thought
Old Mar 25, 2010 | 09:43 AM
seojea's Avatar
seojea
here they are
here they are
Old Mar 25, 2010 | 10:12 AM
MINIdave's Avatar
MINIdave
What does it say in your manual, or on the sticker on the door?
That's a good starting place, then adjust a little up or down based on the wear and handling you want.
40 is too much unless you're running at the track (and then it still might be), that's the max pressure the tire is rated for, it'll ride like it's on rocks at that press.
You might start at 35...
Old Mar 25, 2010 | 01:04 PM
slinger688's Avatar
slinger688
205/40 r 17
Any thought
Is this a first gen Mini (r50-r53) or a second gen mini (r55-r57)?
Seems like the recommendations on tire changes are a little different. I can only say that for a r56 with the 17" rim option, the tire pressure is 38 psi all around as stated on the door sticker. I think it is a little high especially with the sport suspension but that is the recommendation.
Old Mar 25, 2010 | 01:27 PM
seojea's Avatar
seojea
it is an r56 but the rims and tires are after market
i droped them down to 35 but Im thinking it need a bit more air
Old Mar 25, 2010 | 01:32 PM
slinger688's Avatar
slinger688
Add a little (1-2 psi) to see if you like how it drives ...
khumpert
Nov 30, 2015 11:48 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
oldkid6
Aug 30, 2015 08:28 AM
JamJam43087
Aug 16, 2015 02:02 PM
nomar116
Aug 9, 2015 09:42 AM
