205/45/17 vs 215/45/17 What looks better?
Im replacing tires on my S-lites, and I cant decide between 205/45/17 vs 215/45/17. What do you guys think looks better? Anyone want to post some pics to help me decide? Im hoping the 215/45 will close the wheel gap a little bit.
Any performance advantages for one or the other?
Thanks!
Thanks!
Thinking of picking up a set of "Bridgestone - Potenza G019 Grid with Uni-T" from Costco. They're $409 installed (after $70 instant rebate) and they come with lifetime nitrogen inflation, free lifetime rotation, and free lifetime hazard protection. Seems like a good deal. What do you think?
http://tires2.costco.com/SearchResul...a-c8ce86c2ae8e
Good point.. I just wanted a little buffer for pot holes and to give the car a little better ride. I live in Chicago, and the roads are horrible. Can I go wider w/out going taller?
I have run both and I prefer the 45 series for a couple of reasons .
They ride softer do to the extra volume.
They fill the fender well better which gives the appearance of being lower when the car is actually higher off the ground by a minimal amount when compared to 40 series.
Better rim protection when encountering road hazards such as pot holes.
Easier entry and exit from steep driveways etc.
Randy
M7 Tuning
First two photos is with my track wheels and 40 series . The rest are with my 45 series sets.
Randy
M7 Tuning
Yes, but just don't go too wide so that clearance becomes an issue.
215/40 is only a tiny bit shorter, 215/45 is a tiny bit taller. Unfortunately they don't make anything like a 215/42 for you :P
Rough Roads in IL?
According to the tire calculator, thats actually a little smaller. 215/45 would be plus size, no?
I'll just bring a winter tire and say thats my spare... They're giving me a hard time about selling me a 215/45 instead of the OEM 205/45 too.. Whats their deal?
Just tell them you're well versed in tire sizes and understand what you're ordering.
No, Plus 1 is one size wider in tread width and one size smaller in sidewall. It meant to gain better traction and better gearing and steering response, not to compromise the latter. From OEM 205/45-17 that wold be 215/40-17.
Yes little smaller provides better gearing, I now use 15's for a lot smaller and better gearing. 40 series tire also provides better steering response.
Randy
M7 Tuning
1. Plus Zero
This method utilizes the same wheel diameter as Original Equipment (OE) but incorporates a tire with a larger than OE section width and smaller than OE aspect ratio. For example, replacing an OE 175/70R14 tire (on a 5.5-inch wheel) with a 195/60R14 tire would be a proper Plus Zero fitment. Note that this practice may require a replacement wheel in order to maintain proper rim width for the new tire.
2. Plus One This method utilizes a one-inch larger diameter wheel in conjunction with a tire of a one-step lower aspect ratio. An example of an appropriate Plus One fitment is to replace an OE 175/70R13 tire (23-inch overall diameter) with a 185/60R14 tire (22.9-inch overall diameter). Note that this method always requires a replacement wheel.
2. Plus Two
This method utilizes a two-inch larger diameter wheel in conjunction with a tire of a two-step lower aspect ratio. An example of an appropriate Plus Two fitment is to replace an OE 175/70R13 tire (23-inch overall diameter) with a 195/50R15 tire (22.8-inch overall diameter).
