Brake Pads for Track Days
Old Mar 24, 2010 | 08:15 AM
GO K4RT's Avatar
GO K4RT
Well I am looking to get my 2009 S out on a road course in the next couple of weeks and I am concerned that the factory pads will not be able to withstand the abuse of the day. Because of this I am looking into getting a different pad but I am not sure what are good options. I don't mind swapping pads so I am open to the option.
The Hawk HPS pads are appealing because they are relatively cheap along with the Porterfield R4-S pads that I saw on Texas Speedwerks. Anyway I was wondering what people recommend for a pad that will see the occasional track day.
Thanks for you help.
Old Mar 24, 2010 | 08:54 AM
C-Lop's Avatar
C-Lop
I have theHawks and love them. but a word of caution, if you get them take them out and do some heavy braking with them. Mine were slick for while until I got them worn in.
Old Mar 24, 2010 | 09:22 AM
GO K4RT's Avatar
GO K4RT
Did you do a bedding procedure for them?
Old Mar 24, 2010 | 12:39 PM
btwdriver's Avatar
btwdriver
The dilemma with what you are asking is that what is good on the track is not good on the street and vise-versa. I would recommend something more aggressive for the track than the HPS pads. Something like the CarboTech XP10 on the front and XP8 on the rear. Or if you like Hawk, maybe the DTC-60's. The PorterField R4-S are not track pads, even for the rear.
Old Mar 24, 2010 | 02:34 PM
quikmni's Avatar
quikmni
I agree with btwdriver that the Hawk HPS are not aggressive enough for the track. I use the Hawk HPS on the street but I change pads for the track.
Saying that, I used stock pads at the first two track days that I went to and the pads lasted through both events. However, I did have brake fade and had to slow down. Since then I have installed larger brakes.
Old Mar 24, 2010 | 07:53 PM
GO K4RT's Avatar
GO K4RT
Did you warp your rotors at all? I am wondering if brake pads would even help that issue?
Old Mar 24, 2010 | 08:20 PM
btwdriver's Avatar
btwdriver
I have completely abused numerous brake pads and boiled all kinds of fluid. I have never warped a set of rotors on the MINI. Cracked them yes, but never warped.
I take if from your comment that you have had that issue?
Old Mar 24, 2010 | 08:32 PM
quikmni's Avatar
quikmni
My stock rotors did not warp. I think the fluid and pads started to give up before the rotors got too hot. My guess would be that better pads and hi-temp fluid would tend to put more heat into the rotors which could cause cracks or even warpage. However, it seems like the stock rotors can take a lot of abuse and not warp.
Old Mar 24, 2010 | 08:43 PM
GO K4RT's Avatar
GO K4RT
I haven't tracked the Mini yet, I just posted the same question on the local Mini board and receive a response from someone who did. I am not sure if it was an r53 or an r56.
I sent a pm to a local carbotech dealer on a local board about some pads. If they can get me a good deal, I will probably pick up xp10s for the front and xp8s for the rear.
Old Mar 24, 2010 | 09:26 PM
Cookie1's Avatar
Cookie1
The Porterfield R4, is a good track pad if you dont mind changing them out. Very dusty and some noise. Easy on rotors.
Old Mar 24, 2010 | 09:50 PM
slinger688's Avatar
slinger688
What you need does depend on your skill level on the track.
There are street pads like Mini OEM, aggressive street pads such as Hawks HPS. These are usually not enough pad for the track.
Then there are track pads from mild to aggressive. Much of the ratings on track pads has to do with the friction coefficient and heat range. The milder pads have lower heat ranges and lower friction coefficient. Most manufacturers offer track pads from mild to aggressive.
If you want a good intro track pad, try the Carbotech XP 10 in the front. It is important to be with more than enough brakes on the track.
Old Mar 25, 2010 | 05:49 AM
btwdriver's Avatar
btwdriver
I have run the R4 pads in the rear. Just as fair warning, I had to grind the tabs down to get them to fit on my R56. Not much mind you, but they were not a drop in fit like every other pad that I have used.
They also didn't last very long.
Old Mar 25, 2010 | 07:13 AM
slinger688's Avatar
slinger688
Again, depending on your driving skill, braking needs and the track situation, track pads typically last about 3-5 track days in the front.
The rear pads can sometimes last about two to three times longer.
Old Mar 25, 2010 | 07:17 AM
btwdriver's Avatar
btwdriver
Understood, I run in the advanced run group and do 30+ track days a year. My experience with the R4 pads in the rear is they only lasted around 6-7 days. Other pads that I have run, like the Hawk DTC-60, lasted at least a half a year.
Old Mar 25, 2010 | 07:42 AM
slinger688's Avatar
slinger688
I also run in the advanced group with about 20-25 days a year. I run CT XP8 in the rear so about 14-16 days of track. Funny, I found in thr front, the XP12s wear better than the XP10s. Must be the heat range.
R4 seems to wear down quite a lot quicker in the back. Good to know.
Old Mar 25, 2010 | 08:04 AM
JumpingJackFlash's Avatar
JumpingJackFlash
In addition to whatever pads you select, also consider at getting upgraded rotors. M7 has the complete kit of drilled/slotted rotors for $339. Go here: http://www.m7tuning.com/parts/produc...roducts_id=161.
If you had a 1st gen MINI, Turner Motorsport still has front and rear drilled rotors for $120/pair. That's only $240 total.
Old Mar 25, 2010 | 08:38 AM
slinger688's Avatar
slinger688
I find the R56 MCS stock rotors to be surprising good, even though they do develop miniature heat cracks (as mentioned by btwdriver).
While I used to run drilled rotors on the track with my 911 and Lotus without issues, it seems that they are not recommended on a Mini due to stress cracking. This seems to be especially true for the OEM Mini JCW drilled rotors (not so on the regular JCW rotors). Drilled rotors could also shorten the life of a brake pad.
Old Mar 25, 2010 | 11:03 AM
GO K4RT's Avatar
GO K4RT
So you think only front pads then? It shouldn't interfere with the way the car handles? If so, I could probably live with that.
Old Mar 25, 2010 | 11:34 AM
Z06C5R's Avatar
Z06C5R
Have you looked at Hawk HP plus pads? I have them in my 39-year-old Datsun autoX car, and it breaks harder than my MINI on HPS pads. They're noisy and dusty, but certainly street-able (unlike most pads that perform similarly). And just for what it's worth - I've used HPS pads on the track without issue. BUT, it was raining intensely. So I suppose that invalidated my results.
Really, it all depends on your situation: If you just want to go out and have fun, you could probably get away with aggressive street pads provided you're cool with slowing down if they start to cook. If you want to go out and run hard for the entire session, you'll likely have to either change pads there, or go with a hybrid pad like the HP pluses. And then of course, you have to consider the track - are there long straights where the brakes can cool? And finally, because no one else has mentioned it yet: Make sure to fully flush the system with a good, racing-type fluid like ATE Super Blue.
Old Mar 25, 2010 | 12:53 PM
slinger688's Avatar
slinger688
If you are a novice, ie perhaps less than three times on the track, it is generally OK to just change to front pads to something like a milder race pad. There are many choices out there from HP+ to CT XP 10, Ferado DS2500 etc...
It does not change brake bias enough to be a problem.
As you get faster, keep better track of the rotor temperatures and tire pressures/temperatures.
W0TM8
Dec 19, 2019 07:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
bjcarter2
Aug 31, 2015 04:03 PM
