After Market rims and tires tpms
Old Mar 24, 2010 | 07:57 AM
seojea's Avatar
seojea
Is there any way to disable tpm.. I recently purchased a set of after market rims and tiers.. Without the tpm in them.. Of course the Tpm Light is on the hole time now..
Is their any solution I can do my self? I.e. Turn it off or disable the monitoring?
Old Mar 24, 2010 | 08:49 AM
R56Convert's Avatar
R56Convert
I asked the same thing when I had my GTI and the dealer acted like I was a felon..... without messing with the computer I dont think so. Its a big brother government thing... they want to make sure our tires are properly inflated apparently its a national security thing
Old Mar 24, 2010 | 08:58 AM
iwashmycar's Avatar
iwashmycar
Nope...have to transfer the TPMS to the new wheels, or buy more sensors ($200+)
Old Mar 24, 2010 | 09:01 AM
seojea's Avatar
seojea
I wonder what it cost to get them moved over?
Old Mar 24, 2010 | 10:08 AM
t0ad's Avatar
t0ad
AFAIK there's nothing (easy) that you can do to defeat the TPMS system. I just roll on my aftermarket wheels with the warning light on all summer .. you get used to ignoring it, and it's a lot cheaper than buying more sensors! However, if you're just swapping over to an aftermarket set of wheels and only using them instead of swapping out each season, any tire shop should be able to move the sensors over to the new wheels for you when they mount and balance them.
Old Mar 24, 2010 | 10:16 AM
iwashmycar's Avatar
iwashmycar
I had almost new tires, and my TPMS moved from a stock set of wheels to some new rims and it was about 100 bucks... they were also balanced. So for 25/ea they took off a tire, installed TPMS, put on a tire, and balanced...
Id expect something similar to do basically the same thing, if you already have tires mounted on said rims
Old Mar 25, 2010 | 08:23 AM
seojea's Avatar
seojea
I think im just going to deal with it for now ...
The tires are on the car..
Old Mar 25, 2010 | 09:49 AM
iwashmycar's Avatar
iwashmycar
ya i delt with it all winter as i left them out of that set. its just the light and the tach display at startup... i completely got used to it.
Old Mar 27, 2010 | 04:20 PM
manish's Avatar
manish
TPMS Doesnt fit on all rims?
I have an 08 MCS. Went to the dealer this morn, have a nail in one of the runflats. so instead of buying 1 runflat for $250 i was going to buy 4 non runflats for $400.
So I asked the dealer about mounting the TPMS on another rim, and he said it depends on the rim, some rims, the mini TPMS cant be installed on.
I wanted to put the TPMS on a set of Gen 1 Bullets. Anyone know if that will work?
Old Mar 27, 2010 | 04:24 PM
iwashmycar's Avatar
iwashmycar
yeah there are some but usually with the stem in any normal spot theyll fit...
im pretty sure all MINI wheels should work fine, regardless of gen
Old Mar 27, 2010 | 06:00 PM
Robin Casady's Avatar
Robin Casady
Most tire dealers can supply you with TPMS that will fit a particular wheel and work with a MINI. You'll probably save $$ by having your tire work done somewhere other than a MINI dealership. In some cases they charge double what a good tire place will charge.
FLYM1N1
Oct 13, 2015 04:33 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
hexproject
Sep 7, 2015 08:23 PM
TOMSR53
Aug 26, 2015 10:18 AM
Dashdog
Aug 10, 2015 06:17 AM
