Check Engine Light and Just bought my JCW! Hearing Fireworks!
Old Mar 23, 2010 | 11:22 PM
Mpower510's Avatar
Mpower510
Finally got my dream car (ebay) and CEL comes on! i have a 06 JCW with almost 120k miles, i thought the car looked in decent shape but after i bought it and came home, CEL came on. I ran a diagnostic and here it is:
P2270 - O2 Sensor Signal stuck lean - bank 1 sensor 2
P2096 - Post Catalyst Fuel Trim System Too Lean or Post Catalyst Fuel Trim System Low Limit
P0137 - 02 Sensor Circuit Low Volts (Bank 1 Sensor 2)
P0130 - 02 Sensor Circuit Malfunction (Bank 1 Sensor 1)
I'm guessing i need a new Cat :-/ ??? When i'm driving it, the car is making a very loud noise coming out from the bottom middle of the car and when changing around gears and accelerating, i hear fireworks spitting out from the car.
Old Mar 23, 2010 | 11:52 PM
markjenn's Avatar
markjenn
When you buy an Ebay car with 120K you should probably expect some deferred maintenance and problems. The trouble codes might be as simple as an O2 sensor. The "loud noises coming from the bottom middle of the car" might be more significant, but you're not going to get much useful info with descriptions like "fireworks spitting from the car".
Give the car a chance. Find a good mechanic and work the problems. It might be a big deal, it might be minor.
- Mark
Old Mar 23, 2010 | 11:57 PM
Mpower510's Avatar
Mpower510
well yah i'm pretty sure it needs a new 02 sensor and the noise issue, its pretty much a loud noise coming from under my seat towards the engine and i'm guessing based on the codes, it just needs a cat
Old Mar 24, 2010 | 04:40 AM
BlimeyCabrio's Avatar
BlimeyCabrio
May just have an exhaust leak... hole in the exhaust... header leak... missing O2 sensor... all kinds of things it could be other than a bad cat.
Old Mar 24, 2010 | 08:01 AM
JumpingJackFlash's Avatar
JumpingJackFlash
Unless the catalytic converter is clogged, it should last for many years. The O2 sensors are supposed to be replaced around 100K miles. Usually, you only have to worry about the one located pre-cat. The post-cat O2 sensor is designed to read and make sure the catalyic converter is working correctly. It gets less carbon emissions and lasts longer.
I would also check the wiring. Perhaps something just came loose.
Old Mar 26, 2010 | 03:41 PM
Mpower510's Avatar
Mpower510
Got the car checked at the dealer and they say:
Needs a new JCW Cat
Bushings Torn
Power Steering Rack
Thermostat
Old Mar 26, 2010 | 05:25 PM
ntmid8r's Avatar
ntmid8r
Now that you know the problems, get a second opinion from a local shop, save some cash and shop around. Im sure the dealer will charge the most.
With that mileage I wouldnt doubt some of the issues could arrise but curious how the steering rack went bad, other than running low on fluid perhaps?
Old Mar 26, 2010 | 09:41 PM
Mpower510's Avatar
Mpower510
Dealer quoted me $6k lol they said the Cat cost $2k but i am looking mainly for a cat for now since that is the main issue. Would a type S cat fit on a JCW?
Old Mar 27, 2010 | 12:00 AM
Oxybluecoop's Avatar
Oxybluecoop
You can get a catted Milltek header from Helix for around $1100.
Old Mar 27, 2010 | 06:48 AM
davisflyer's Avatar
davisflyer
You could probably go to a good muffler shop and have a hi-flow cat installed for $2-300.
Old Mar 27, 2010 | 06:49 AM
davisflyer's Avatar
davisflyer
Helix used to sell OBX w/cat for half that price. I wonder what happened???
Old Mar 27, 2010 | 06:52 AM
MiniCoopaloop's Avatar
MiniCoopaloop
its definitely exhaust related...does the car seem weak? If the converter is clogged you may lose a significant amount of power. We had a grand prix with a clogged cat...couldnt go over 25 mph...it was like I hit a switch and the car turned "Grandma mode" on me. Hope you get it fixed and start motorin...
Old Mar 27, 2010 | 07:32 AM
Oxybluecoop
They sure did. That was the first thing I looked for but it was gone.
Old Mar 27, 2010 | 10:26 AM
Mpower510's Avatar
Mpower510
The car doesnt seem weak but its just when your on first gear, you hear a lawn mower type of sound lol and i'm looking for a oem cat preferably JCW or S, hopefully someone in the states has one...
Old Mar 27, 2010 | 10:33 AM
Oxybluecoop
Old Mar 29, 2010 | 06:36 AM
davisflyer's Avatar
davisflyer
I believe that the stock exhaust manifold or header is the same whether it's JCW or S. For the exhaust, I belive it's only the cat back portion that is different. Therefore, you can probably find a used S header for cheap, under $200
Old Mar 29, 2010 | 11:30 AM
Mpower510's Avatar
Mpower510
yah your right, i have been looking around and i don't need the headers, just the cat :-/
Old Mar 29, 2010 | 11:47 AM
NAPMINNI's Avatar
NAPMINNI
I would try a local shop. There r used headers that go for 100 bucs in the marketplace.
Old Mar 29, 2010 | 01:42 PM
davisflyer's Avatar
davisflyer
You could probably replace with a used header/cat for less than buying a cat and having to get it welded in!
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
TunedGP
Oct 1, 2015 04:18 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
