JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Filter Upgrade for JCW Tuning Kit Airbox (Stage 1)
Old Mar 16, 2010 | 03:44 PM
akng's Avatar
akng
I got a 2009 R56 Cooper S and I am looking to upgrade the Air Filter for my JCW Tuning Kit Airbox (Stage 1). I am currently looking to decide one from MINI Madness and MINI Mania. Which one is better one in terms of results and fitment? Or is there one that's better than both of these in terms of results and fitment? Please advise! Thanks!
Old Mar 17, 2010 | 08:56 AM
scottab36's Avatar
scottab36
I am running the Mini Madness one and I love it. Fitment is great and much better driveability.
Old Mar 17, 2010 | 09:03 AM
akng's Avatar
akng
I heard from someone that you will have to cut something in the airbox to fit the filter inside. Is that true? Cuz it doesn't really make sense to me! Or is that the MINI Mania one? I am just confused!
Old Mar 17, 2010 | 09:05 AM
scottab36's Avatar
scottab36
No cutting required on the Mini Madness JCW stage one replacement cone filter. Drops right in; takes about 5 minutes!
Old Mar 17, 2010 | 11:32 AM
mikemc's Avatar
mikemc
i use the maddness filter and it works good. i did have to make a small cut to get the filter to fit tight on the inside of the airbox. it kept coming loose. its really not a big deal though. you just trim the corner of the inside, side piece so the filter wont slip off.. now its on tighter then before and provides me with good piece of mind.
Old Mar 17, 2010 | 12:12 PM
akng's Avatar
akng
Thanks guys for the comments so far!
Does anyone have experience with the MINI Mania filter? Their filter comes with some metal plate to keep the filter in place. So perhaps this is one advantage over the MINI Madness filter in terms of fitment? Any advices?
Old Mar 17, 2010 | 02:05 PM
mikemc's Avatar
mikemc
looks like the same thing to me.. why do you think it comes with a metal plate to keep the filter in place? probably does the same thing as cutting it IMO... the overall look is the same.
Old Mar 17, 2010 | 02:29 PM
akng's Avatar
akng
According to this:
http://new.minimania.com/web/Item/G2.../InvDetail.cfm
The MINI Mania filter comes with a metal plate to keep the filter in place. Is the metal plate's location the same place that you had to cut into the airbox then?
Old Mar 18, 2010 | 07:47 PM
mikemc's Avatar
mikemc
looks like they figured that one out!
Old Mar 19, 2010 | 01:52 PM
akng's Avatar
akng
I guess that justifies why the MINI Mania filter is $10 more than the MINI Madness filter then!
Old Mar 21, 2010 | 12:39 AM
slinger688's Avatar
slinger688
I have Mini Madness as well. I just put a velcro (hook) on the filter housing and the loop side on the filter to hold it in place. Works fine w/o cutting or drilling etc.
I think this is much better than the foam ones.
Old Mar 25, 2010 | 08:46 AM
akng's Avatar
akng
So seems like most people has the MINI Madness filter!
But does anyone else have the MINI Mania filter? If so, it would be much appreciated that they could share their experience! Thanks!
Old Mar 27, 2010 | 07:20 PM
scottab36's Avatar
scottab36
Here is the MINI Madness replacement filter installed in the R56 JCW airbox:
Not sure what some folks needed to cut. As you can see it fits great.
Factory R56 airbox bottom piece remains:
Old Mar 28, 2010 | 10:31 PM
mikemc's Avatar
mikemc
the filter slides or vibrates off... at least mine did... check it in about a month or less just to be sure... i made a small cut to where the base of the filter sits and it slids down more & holds on much better... corner cut, about the size of a finger nail was all it needed for me for that little more grip...
Old Mar 29, 2010 | 03:27 AM
scottab36's Avatar
scottab36
I will keep and eye on it. Mine seats all the way down and I set the clamp screw, after tightening it, with locktite.
Old Mar 29, 2010 | 06:45 AM
slinger688's Avatar
slinger688
I used velcro to faster it so it seems fine as well. Even after 22 track days.
Old Mar 29, 2010 | 07:49 AM
akng's Avatar
akng
Aside from the fitment for now, does the filter alone actually give noticeably better throttle respone and power?
Old Mar 29, 2010 | 11:49 AM
slinger688's Avatar
slinger688
Can be kind of subjective without 0-60 times.
Old Mar 29, 2010 | 12:14 PM
akng's Avatar
akng
But when you do heel toe or double clutch, does it rev up quicker? If so, then the throttle response is considered better!
Old Mar 29, 2010 | 01:28 PM
slinger688's Avatar
slinger688
I don't do double clutch on the Mini. You don't need to on the Mini with Synchromesh. I double clutch when I run open wheels with straight cut gears.
I cannot feel any difference with h-t. Not sure you would because there is plenty of time to shift because of the dual mass flywheel.
Old Mar 29, 2010 | 02:05 PM
akng's Avatar
akng
Okay, maybe not double cluching then! What I meant is rev matching when you downshift! The throttle response isn't too bad right now! But if it's a bit more responsive like NA cars, I would much prefer that instead!
Old Mar 29, 2010 | 06:57 PM
orangecrush's Avatar
orangecrush
I ordered a mini madness filter last week when I took my DDM intake off and installed a JCW intake.
I got 10 bucks that says the throttle response is better.
The reason I say that? With my RMW tune, I was using the DDM street intake. Now that I've installed the JCW intake, my car idles rough and sputters for the first few minutes when it's warming up.
Personally, I think the air flow is restricted and that's why the car doesn't like to idle cold.
I'll bet when I put the new filter in, it'll idle normally.
We'll see.
Mark
Old Mar 30, 2010 | 12:41 PM
slinger688's Avatar
slinger688
We'll see.
Mark
Mark,
I went from a JCW paper to Mini Madness in the JCW intake and did have have any difference in the idle. I had always thought that the filters only made a "slight" difference, perhaps, at high rpms. Maybe it matters more with the tune...
Also, with H-T, it would make very little difference how fast/instant the revs are since it takes time (at least 0.5 secs) to shift gears. Getting up the revs faster is not going to matter especially since we made a slow reacting and heavy dual mass clutch.
Are you going to VIR in June? Would like to take a look at what you have on the track... S-driver and I will be there with our Minis.
Old Mar 26, 2012 | 02:29 PM
conrad0102's Avatar
conrad0102
Just Ordered a filter for my stage 1 from Mini Mania... will come back with fitting results, photos and maybe a before an after sound video for all who are interested.
Old Mar 26, 2012 | 07:42 PM
turtle343's Avatar
turtle343
ive had the mini mania one in for over a year and no probs at all. also no probs with the rmw tune either.
