Dealer says Limp Mode is because of faulty damper!
My '06 MCS/JCW overheated while it was still cool this morning, and after giving it a tall cool drink, it went into Limp Mode. The dealer towed it in and tells me the problem was a faulty Damper.
Does this sound right? I need some intelligence on this. Any informed reply welcome!
Yep. Damper (crank pulley) fails - as a result the belt will either break or will just "sit there" - but will not turn the AC, Alternator, supercharger or water pump. No water pump = overheating. No boost from SC = limp mode.
Mine failed 2 weeks ago and resulted in a 90 mile flatbed ride home. I replaced mine with an ATI Super Damper from WayMotorWorks, which is quite different and will never fail like an OEM replacement damper may...
Replacement is fairly straightforward (only took me about an hour), but I'm sure the dealer will overcharge for this big time.
Cool! Yep, extended warranty is good in this case!
As long as you didn't drive the car long with it overheating, you should be fine once the new damper & belt are installed and coolant is topped up.
Sc00terbum
Sep 11, 2015 07:17 AM
mimaal
Sep 4, 2015 09:09 AM
