can't find 205-55-17, any suggestions
Old Mar 11, 2010 | 08:42 AM
chilimac's Avatar
chilimac
I am looking to buy a set 205-55-17 for summer. Comfort and noise levels are the top priority as I run seperate wheels and tires for track events. Tire rack only has three options on that size.
What brand would you recommend and which vendor?
thanks
Old Mar 11, 2010 | 08:59 AM
tpetro33's Avatar
tpetro33
Howdy,
If you look for 205-45-17 or 215-45-17 you'll get a ton of choices and your speedo will still read accurately........Good luck!
Old Mar 11, 2010 | 09:05 AM
chilimac's Avatar
chilimac
thank you for the suggestion. i am running 205-45-17 yoko evs currently. They are great tires however just not comfortable enough for Denver streets. I would like to increase the shoulder of the tire to get a little more comfort during the week.
Old Mar 11, 2010 | 10:06 AM
joshknot's Avatar
joshknot
Are you sure you really want to increase overall diameter that much? It's not just your speedometer that will be off; your odometer will be increasing at a (fairly significantly) reduced rate.
Why not consider dropping down to 16" wheels if you're concerned about comfort? At least in that situation running a 55 series sidewall would be appropriate. Hell, I've got a set of 16" bridge spokes if you're interested.
Old Mar 11, 2010 | 10:15 AM
joshknot's Avatar
joshknot
Oops...double post.
Old Mar 11, 2010 | 10:33 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Not to mention the gearing and slowing down your acceleration a good bit.
Old Mar 11, 2010 | 11:03 AM
chilimac's Avatar
chilimac
Thanks for all the input. Your points make sense.
I have a set of 17" TDR wheels that I want to use thus stay in 17" range. Based on your input now I am thinking about 215/50/17.
205/45 (my current size) has a radius of 308mm
215/50 has a radius of 323mm
205/55 has a radius of 328.5
Speedometer difference should be around 5%.
I am not terribly concerned about gearing and accelaration decrease since that is why I run 16" wheels with 40 shoulder on the track.
This set is for commuting only.
Now if anyone has a 16" set of white TDR wheels to swap for 17"s that is a different story.
Old Mar 12, 2010 | 02:00 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Wow that's Thin and Tall.
sevin
May 2, 2026 06:11 AM
HaveATank
Aug 24, 2015 10:26 AM
maniacalmorgan
Aug 21, 2015 03:03 AM
maniacalmorgan
Aug 20, 2015 01:08 PM
PSIChocolate
Aug 13, 2015 12:46 PM
