Suspension h sport springs..do i need control arms if lowering only 1 inch?
Old Mar 7, 2010 | 05:37 PM
zachsa's Avatar
zachsa
the title says it all..installing h sport springs on my cooper s with factory sport suspension...will i need control arms to adjust the camber...how much will the 1 inch lower stance mess up my camber on the stock control arms
Old Mar 7, 2010 | 06:19 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Idealy, adjustable rear control arms and some even spring for the front adj front camber plates but not necessary. Just end up with some negative camber issues like uneven tire wear across the face of the tire and some great go-dart type handling that goes along with it.
Theoretically it could also put stress on the wheel bearings possibly causing them to go bad sooner.
Old Mar 7, 2010 | 07:50 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes, go ahead and get some Hsport control arms. That way you can correct the rear camber and save your tires. I always recommend adjustable camber links when lowering your car.
Old May 7, 2010 | 07:58 AM
XXLil MickXX's Avatar
XXLil MickXX
control arms
Old May 9, 2010 | 10:19 AM
CRoth's Avatar
CRoth
I put H-Sport adjustable rear control arms on mine after installing the springs. This not only enabled me to set my camber properly but also leveled my ride out so the back was even with the front. While you're doing this job you might want to consider installing an aftermarket rear sway bar. I'm using the H-Sport competition set on the middle hole. This made a huge difference! Absolutely got rid of all the understeer, it was like a cometly different car after the springs, sway bar and control arms.
Old May 10, 2010 | 11:03 PM
Mister-Aandrew's Avatar
Mister-Aandrew
^do you have pics of your setup??
id love to see the stance.
Old May 11, 2010 | 01:14 AM
CRoth's Avatar
CRoth
Yes, just veiw my gallery. I don't have time to post them here now but I will later.
Chad
Old May 11, 2010 | 08:34 AM
rjtrout2000's Avatar
rjtrout2000
Well, I have been running TSW springs now for about two years and I still don't have the adjustable control arms. I was intending to buy them, but there was such a small variance in rear camber that I decided not to purchase those, but rather an extra set of rubber for the track!
iirc, the H-Sport lowers a car about the same as the TSW, so I would think that you could install the springs for now, and get away without adjustable hardware. Just my opinion.
ebowling
90
Aug 4, 2019 09:15 AM
Manny_cooper
Nov 4, 2015 09:42 AM
yukinoinu
15
Aug 24, 2015 09:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
