New Project 2004 MCS...
Old Mar 3, 2010 | 07:42 AM
StallionMotorsports's Avatar
StallionMotorsports
SteelHorseRacing
Wow, 2010 Sounds like its time to start a new project...
I will call it the SteelHorse...
I need to set this beast up with Tires/Wheels and Brakes for the Track and maybe a few runs down the interstate for high speed testing...
I have moved on from Diesel Truck pulling competition and want to get on the track...
Your Suggestions will be helpful...
Thank You..
Old Mar 3, 2010 | 07:45 AM
Helix13mini's Avatar
Helix13mini
Well you've come to the right place to find information, and there's a lot of it. Try searching for things like 'pulley' and 'tuning' and 'swaybar' and you'll get a wealth of information. You might also check vendor sites such as, say, www.helix13.com.
Old Mar 3, 2010 | 08:42 AM
StallionMotorsports
SteelHorseRacing
Thanks Helix13, A person can get lost with all this information.. I may try and contact owners who are on the track and pull information from them...
Thanks Again...
Old Mar 3, 2010 | 08:56 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Try this: Heartland Park of Topeka Touring Club
Also, local chapter of SCCA.
Pulley, Rear Sway Bar, High Temp Brake Pads, High Temp Brake Fluid
Old Mar 3, 2010 | 10:00 PM
BensMini's Avatar
BensMini
Good luck on your SteelHorse project, keep us informed as to progress, some words and pics.
Old Mar 4, 2010 | 04:58 AM
StallionMotorsports
SteelHorseRacing
Heartland Park in Topeka, I got to drive that track years ago before they reconfigured... I went to a driving school one weekend and worked with Jim Wheeler... He races in A sedan class... I am trying to get this MCS up to snuff for this summers driving classes...
I will take alook into the club and find someone who races MCS...
I will also keep the pics and info posted...
Thanks for all the Info...
Old Mar 4, 2010 | 01:04 PM
StallionMotorsports
SteelHorseRacing
First Look:
The Mini needs a new engine motor mount. Sounds like the 2004s have a problem with leaking.
I would like to put on something a little better than factory.
Whats out there?
And when I do change the mount should I put the 15% S/C pulley on at that time to save me the pain of taking it loose again...
And when I do replace the pulley should I do the crank pulley at the same time....
Thanks for the help....
Old Mar 4, 2010 | 03:25 PM
howsoonisnow1985
BSH Lower Motor Mount
TSW Lower Motor Mounts
Powerflex bushing replacement
Old Mar 6, 2010 | 08:03 AM
StallionMotorsports
SteelHorseRacing
The SteelHorse Project is underway...
Replaced Falken tires with a set of Hankook Ventus for now until I get the track tires and wheels sorted out...
Ordered MSD Coil/Wires/Plug Kit from Alta...
Alta 15% Pulley/Belt Kit...
AFE Stage 2 Air Intake System... (Ran these systems on all my trucks)....
Engine Mounts Upper and Lower...
Oil Changed to Royal Purple New Filter...
Brakes?
Strut Tower Brace? Lots to choose from...
Strut Tower Plates?
Lower Frame Strut?
The Mini came with a rear sway bar from the factory Not quite sure what thickness yet?
Looks like I need a new valve cover gasket...
Complete Chassis Power Wash and Repaint...
Suspension Components?
Exhaust Systems?
Thanks for any and all your input that you have...
bahman
Feb 14, 2016 10:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Fordgt4
Oct 10, 2015 10:42 AM
M7Speed
Oct 1, 2015 07:05 AM
bahman
Sep 30, 2015 01:59 PM
