correct tire pressure for 04mcs all season?
Old Nov 16, 2003 | 11:30 AM
jomo's Avatar
jomo
All season runflats.04mcs.average load;2people.winter driving.What should the tire pressure be kept at.[goodyear eagles]. THANKS-JOMO.
Old Nov 16, 2003 | 11:50 AM
SCCA's Avatar
SCCA
Should be around 38-42 PSI and should tell you on tires sidewall.
Old Nov 16, 2003 | 11:55 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Jomo,
Aloha and welcome to NAM,
Look at your inside driver's door jam and find the metal plate that has the grid of different wheel options and recommended tire pressures for the MCS. Look for your tire size and then look under the amount for two people.
About 33 psi cold front and back. Higher for 4 people (max load) about 38 psi.
_________________
ALOHA
Old Nov 18, 2003 | 06:46 AM
Alex@tirerack's Avatar
Alex@tirerack
The sidewall pressure labled is MAX for that tire. Minihune is right on at 33 psi cold.
Alex
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
