Vibrates at 3k+
Old Feb 25, 2010 | 04:58 AM
dustinhxc's Avatar
dustinhxc
Vibrates at 3k+
When I go above 3k the car is vibrating. Any ideas? Thanks
Old Feb 25, 2010 | 06:05 AM
Fatherdeth's Avatar
Fatherdeth
Out of balance wheel, alignment issues, or the worse could be worn out bushings in the front. These are the simplest ones to look at first.
Old Feb 25, 2010 | 06:28 AM
lowmini's Avatar
lowmini
Dose it go away with speed change?? or engine rpm ??
Old Feb 25, 2010 | 09:43 AM
dustinhxc's Avatar
dustinhxc
Alright I drove it home and stepped on the supercharger tried diff gears going lightly and going hard on it. Didnt do it as much. A bit around 3k for 3rd and 4th gear. around 50mph in 5th and 6th. mainly only when boost is used too.. i never did get an alignment after i installed springs. (because i am getting coilovers real real soon)
Old Feb 25, 2010 | 09:56 AM
lowmini's Avatar
lowmini
do you have the factory LSD ? i know that they had some problem with noies somtimes
Old Feb 25, 2010 | 10:20 AM
dustinhxc's Avatar
dustinhxc
I know I have ASC and DSC. How would I know if I have LSD?
Old Feb 25, 2010 | 10:27 AM
dustinhxc's Avatar
dustinhxc
Originally Posted by Stingray65
your crank pulley may be failing.
Really damn.. There is one that can give me more power right? lightened or something.
Old Feb 25, 2010 | 10:34 AM
dustinhxc's Avatar
dustinhxc
Are the bushings with the springs? I remember when we installed my springs the rubber that was w the springs was super worn out . When I get coilovers it will replace those too right? I'm getting the vmaxx .
Old Feb 25, 2010 | 10:51 AM
dustinhxc's Avatar
dustinhxc
http://www.altaperformance.com/produ...Pulley-R53-R52
what are the different %
Old Feb 25, 2010 | 11:00 AM
ZippyNH's Avatar
ZippyNH
You can add the percent oversize to your pulley reduction...so if you get a 2%, and you have a 15% sc pulley, you end up the same as a 17% SC reduction pulley.
I strongly reccomend if you decide to replace your crank pulley, you stick to a dampened one...WayMotorWorks sells some dampened pulleys that are lighter than stock.
Jan at RMW has stated he has seen several failures of undampened pulleys...in the indrustry, if your car came with a dampened pulley, it is strongly recommended to replace it only with a dampened pulley...to ensure crankshaft, bearing, and seal life.
Old Feb 25, 2010 | 11:03 AM
ZippyNH's Avatar
ZippyNH
Before you go randomly spending money on parts...I would get you car checked out...the vibration could come from many things...worn axels, bad alighnment, etc....
Old Feb 25, 2010 | 12:09 PM
MINIdave's Avatar
MINIdave
And the fact that he lowered it?
Many, many variables here, I also would not just go throw money at parts for it till you know what you're up against....
Could be a motor mount too....
Old Feb 25, 2010 | 02:26 PM
dustinhxc's Avatar
dustinhxc
Thank You guys.
Old Feb 25, 2010 | 03:17 PM
dustinhxc's Avatar
dustinhxc
I have a 17% Pulley which is reaching 19psi maybe I shouldnt get higher than 0% crank? is it safe?
Old Feb 26, 2010 | 07:18 AM
lowmini's Avatar
lowmini
thats alittle high your gona end up spinning the charger too fast, its going to burn out in time, i have a customer that put a 19% on the car in 2002 now he has got around 150,000Km and hes only hitting 12 psi now. so it your gona use a alta crank pully use a 0% so its stock size dont go oversized..... i dont recomend them i have had them brake on the track... The 2005 crank pully is differnt than the 02-04 pullys and its a better style.
Old Feb 26, 2010 | 09:47 AM
dustinhxc's Avatar
dustinhxc
Thank you very much for your input. So what Crank Pulley do you recommend? Just a stock replacement?
Old Feb 26, 2010 | 10:13 AM
ZippyNH's Avatar
ZippyNH
The non-oem one waymotorworks sells is actually better than stock...cheaper too...it might still be on sale too!! If you already have a 17%, I would strongly reccomend you use the stock size. Does the damper look bad?
Old Feb 26, 2010 | 10:22 AM
ZippyNH's Avatar
ZippyNH
When you lowered your car, did you just do springs? Did you swap out Anything else? Did this start immidately after you lowered you car?
Is the vibration at 3000 rpm at any speed...or even when not moving?
Old Feb 26, 2010 | 05:10 PM
dustinhxc's Avatar
dustinhxc
Alright its a funny story. My friend gave me his springs since he upgraded to a r56. he thought he gave me his m7s but it was actually his stock s springs. so i replaced my stock springs with his stock springs lol. so i didnt do an alignment. that was last summer. i am getting coilovers in a couple weeks so i will see if it helps anything out. i will look at the waymotorworks crank. thanks. i didnt notice vibration till this week. it only does it in 2-6 gears and around 3k+ while using high boost. edit didnt feel it at all today while driving. odd.
Old Feb 26, 2010 | 05:25 PM
ZippyNH's Avatar
ZippyNH
Maybe an odd harmonic due to having springs of the wrong type, size, or spring rate?!
BMW actually has a website that you enter you vin#, and based upon factory options, tells you the optimum spring rate. Things like sunroof/no sunroof can make pretty big changes in what is optimum.
Old Mar 10, 2010 | 03:05 PM
dustinhxc's Avatar
dustinhxc
Well I finally got the Flow Master tips welded onto my custom exhaust. While he was at it I had him check for anything that could be causing vibration. Found out the problem. Exhaust Hanger Rubber Mounts were cracked. Bought 2 new ones from Motorwerks BMW for a total of $85. Vibration is now gone.
Filmy
15
Jun 6, 2023 06:27 AM
minieater
Oct 28, 2015 02:15 PM
BlueCooperS
Sep 25, 2015 10:06 AM
gpwpat
Sep 15, 2015 11:58 AM
Suspension Products
Sep 10, 2015 11:46 AM
