Passenger Window
Old Feb 23, 2010 | 09:35 AM
jbmiller's Avatar
jbmiller
Passenger Window
My '05 passenger window makes a horrible, almost cracking sound if I attempt to roll it down or up. So for now, I don't do anything. There is a mark in my tint where it looks like something scraped it while rolling down/up (nice stripe right up the middle). I've read where some have given it a good whack on the motor to make it work but my motor works. Any suggestions?
Thanks,
Bill
Old Feb 23, 2010 | 11:49 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Are the 'wiper' seals clean? I'd try cleaning them first.
I drew this a while ago to help illustrate. Repeat until the paper towel comes out clean.
Old Feb 24, 2010 | 01:44 AM
Eric_Rowland's Avatar
Eric_Rowland
Great diagram, nabeshin!
IMO, best bet is to remove the door panel and have a look. They come off fairly easily. For the '05 you need a (tape covered) screwdriver to release the armrest, then just remove all the screws (three around the oval, and one behind the reflector, IIRC) and pop it off. Pull the bottom straight out, then lift up when all the snaps have released. You should be able to see the offending item.
Old Feb 24, 2010 | 06:46 AM
jbmiller's Avatar
jbmiller
Thanks for the responses. I'll remove the panel and check things out and clean if necessary.
TGlax38
Sep 16, 2015 07:26 AM
USA-RET
Sep 8, 2015 01:50 PM
Ntety
Sep 2, 2015 08:39 PM
hardy616
Sep 2, 2015 08:32 AM
