Navigation & Audio Help w/ CD Changer install
Old Nov 15, 2003 | 01:11 AM
Cappy's Avatar
Cappy
OK so I'm audio challenged... I put a Alpine CHA-S634 in my 2004 MCS (Non HK) with the stock Boost CD headunit. I used the BLITZSAFE DMX V.1 and a KCA-130B cable and set the Changer's Bus Selector on #2 (Mini-Bus). Why won't the changer recognize MP-3 files and play them???? Why does the headunit only display the four numer disk and track code rather than the file data???? Where did I screw up the install??? Thanks for any and all help...
John
Old Nov 15, 2003 | 05:39 AM
CharlesWil's Avatar
CharlesWil
ALP DMX V.1 INTERFACE TRANSLATOR
ADVANCED AUXILIARY INPUT INTERFACE TRANSLATOR FOR MINICOOPER RADIOS (MY 2001-2003) TO ALPINE CD CHANGERS.
THIS ELECTRONIC INTERFACE TRANSLATOR IS THE ONLY TRANSLATOR THAT WILL ALLOW THE MINICOOPER (MODEL YEAR 2001 - 2003) RADIOS TO INTERFACE WITH THE ALPINE CD CHANGERS /S601/S604/611/620/630/634*
* REQUIRES ALPINE ADAPTER MODEL KCA-130B
INSTALLATION INSTRUCTIONS:
LOCATE THE MINICOOPER FACTORY CD CABLE IN TRUNK (ON RIGHT SIDE)
PLUG THE 3 PIN AND 6 PIN MINICOOPER CONNECTORS INTO THE MINI/ALP DMX V.1 ELECTRONIC INTERFACE TRANSLATOR AND THE 8 PIN DIN CONNECTOR FROM THE ALPINE CD CHANGER INTO THE 8 PIN CONNECTOR ON THE MINI /ALP DMX V.1 TRANSLATOR.
MOUNT THE ALPINE CD CHANGER COMPARTMENT.
WITH RADIO “OFF” TURN THE IGNITION SWITCH TO THE “ON” POSITION, TURN RADIO ON
PRESS CD BUTTON ON RADIO. MINICOOPER / ALP DMX V.1 AUXILIARY INPUT INTERFACE. THIS INTERFACE CAN BE USED WITH OR WITHOUT A CD CHANGER
PRESS THE UP DISC >> THEN THE DOWN DISC << TO SWITCH BETWEEN THE CD MODE AND THE AUXILIARY MODES. YOU CAN USE THE AUXILIARY MODE FOR MP3, DVD, SATELLITE OR ANY OTHER AUDIO INPUT.
TECHNICAL HELP LINE (201) 560-5000 EXT. 5105 M-F 11AM - 4PM EST
Charles
Old Nov 16, 2003 | 04:21 AM
Cappy's Avatar
Cappy
Charles,
Thanks for your help. I will try this procedure again but so far no joy on getting the headunit to read MP3 files from the changer.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
