CD Keeps Popping Out of Player
Old Feb 17, 2010 | 09:35 AM
Mind.The.Gap's Avatar
Mind.The.Gap
Hey Guys,
I have an intermittent problem where my CD player will eject the disk inside it when I unlock my car and sit inside (I dont even push the start/stop button at all)
I rarely use the CD player since I hook up my iPhone to my AUX plug-in. I am not accidentally pushing the eject button either...
It doesn't happen ALL the time but it gets into moods where it will eject it almost each time I get into the car after leaving it for several hours... maybe it misses me?...
Any suggestions or ideas of what is causing this?
Thanks in Advance!!
Old Feb 17, 2010 | 10:53 AM
strobeyprobey's Avatar
strobeyprobey
https://www.northamericanmotoring.co...door-open.html
Refer to this thread...If you are using recordable media I would recommend changing brands. If this is happening with a "pressed" disc, make sure the disc is clean and not scratched. If that's not the case, then your CD drive is probably bad and needs replacing.
Old Feb 17, 2010 | 11:00 AM
Mind.The.Gap
Thanks so much!! I never even considered it would be the CD itself but I see how that could make sense! I will try that and hope it works!!
scfiveo
Sep 27, 2019 02:27 PM
bahman
Feb 14, 2016 10:29 AM
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
patsum
11
Sep 30, 2015 02:20 PM
TifosinDel
Sep 28, 2015 10:45 AM
