Drivetrain which LSD do i have and how to identify if my pully has been changed???
Old Feb 16, 2010 | 01:46 PM
knotcher's Avatar
knotcher
i just got this Mini and I have a couple of questions. i did some searches and called the dealer and got no help.
it's an 05 MCS with an optional LSD installed. i need to replace the tranny fluid, but i need to figure out which LSD i have first...clutch, gear, viscous??
also, the car came with an aftermarket intake and exhaust so i'm wondering if the PO also did the pully...how can i tell?
Old Feb 16, 2010 | 02:03 PM
ZippyNH's Avatar
ZippyNH
Look on the side of the pulley....if it has been swapped it will usually have a brand name, and a reduction amount in %. The stock pulley is black. Aftermarket pulleys are usually silver or anodized stainless steel. The factory pulley is also pressfit, aftermarkets (for the last few years anway) are almost always a colet/locking ring type of arrangement with boltholes.
The LSD if I remember correctly does not require matainance....the factory unit is a Quaife (spelling is maybe close, sorry), but it is also avalable as an aftermarket ad on.Good find, not many cars were delevered with the LSD installed!!
Old Feb 16, 2010 | 02:30 PM
Crashton's Avatar
Crashton
Your MINI does not use a Quaife LSD (gear type). What they use is called a GNK cone type. More like a clutch type. There is a special fluid that is used. Your dealer parts department can get it for you. IIRC the tranny holds 2 quarts. Like any tranny its fluid should be changed periodically.
Classic MINI gives a nice NAM discount...
Phone:440.205.6404
Congrats on the new MNI.
Old Feb 16, 2010 | 03:34 PM
ZippyNH's Avatar
ZippyNH
Phone:440.205.6404
I guess I might be wrong... I could have sworn the factory LSD was a qUaife LSD....
Old Feb 16, 2010 | 03:40 PM
maxmini's Avatar
maxmini
Crashton is correct , the unit is not a Quaife.
Randy
M7 Tuning
Old Feb 16, 2010 | 05:10 PM
Crashton's Avatar
Crashton
Wish I was wrong, a Quaife would be a much better diff to have.
Old Feb 18, 2010 | 05:57 AM
knotcher's Avatar
knotcher
follow up question...i have 3 quarts of Redline 75w90 gear oil on my shelf, would that work for changing the tranny fluid or do i need to go get some MTL?
Old Feb 18, 2010 | 01:23 PM
Crashton's Avatar
Crashton
That might be OK for a tranny without a slip, but I would not put that in mine. I'm guessing the stuff MINI spec'd & sells has a friction modifier in it.
Did you figure out if your MINI has a reduction pulley?
Old Feb 18, 2010 | 03:42 PM
knotcher's Avatar
knotcher
75w90 does have the friction modifier in it...the 75w90NS doesn't.
http://www.redlineoil.com/content/fi...ech%20Info.pdf
i checked and i do NOT have the reduction pulley.
Old Feb 18, 2010 | 05:28 PM
Crashton's Avatar
Crashton
Time to put a pulley on there. It is the biggest bang for the buck mod you can do to an R53.
Old Feb 18, 2010 | 07:10 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
YES you can use the Redline MTL, we've used it in many cars with good results.
As for the pulley, the stock one is pressed on. An aftermarket pulley would have bolts on the face of the pulley that hold it on. So no bolts means it's stock. Like Zippy said most will have a brand name on the face. The stock is also black.
Old Feb 19, 2010 | 06:07 AM
knotcher's Avatar
knotcher
I was getting differing opinions so i emailed Redline, here's the reply:
Chris,
[FONT=Arial]Thank you for contacting Red Line Oil, in your Mini transaxle I would recommend the MTL. The 75W90 is a higher viscosity than called for and contains a friction modifier so would be too slippery for the synchros. If your limited slip is a clutch type unit some friction modifier may be necessary to control it though excess will affect shiftability. I would start with the MTL straight, if noise is excessive then a slight amount of friction modifier can be added, being aware too much will affect shiftability.[/FONT]
[FONT=Arial]
[/FONT]
[FONT=Arial]Regards, Dave[/FONT]
[FONT=Arial]Red Line Oil[/FONT]
[FONT=Arial]*******************[/FONT]
[FONT=Arial][/FONT]
[FONT=Arial]so i guess MTL it is.[/FONT]
navybsn
R55 :: Clubman Talk (2008+)
Dec 29, 2015 12:32 PM
eatsleepautox
Oct 30, 2015 06:46 AM
dscott90000
Aug 23, 2015 08:21 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
