How to fix squeaky roof?
Old Feb 9, 2010 | 10:19 AM
coogamoogakid's Avatar
coogamoogakid
My 07 Cooper S has developed a squeaky roof when driving on uneven roads/potholes. I can silence the squeaks/clicks by pushing up on the center of the rear glass panel. As long as I apply pressure the squeaking stops. I can sometimes push down around the rear roof panel before getting in the car and then opening the window before closing the door. Is this a DIY repair or does it have to go to the dealer? It didn't do this until the last 6 months or so. Anybody have any ideas on where to start to fix it?
Old Feb 9, 2010 | 11:03 AM
peter314's Avatar
peter314
where are you located? cold climate?
my car makes all kinds of noises cause of the cold, I just solved a bunch of them this weekend with DIY mods, recently the rubber trim where the glass meets the car started making a heck of a racket, cold dry and rubbing against eachother, so I went searching for some rubber moisturizer and while at pepboys the clerk said to put some tire shine on.
once he had said that it made perfect sense. So I did put some tire shine on and the noises went away, its basicly a rubber safe slick lube kind of stuff.
So after success with the door trim last night I put some on the rubber trim around the sunroof just cause. see if that works
last weekend I decded to take care of what I could. Its much quieter now.
hope this can help your problem.
Old Feb 9, 2010 | 03:34 PM
coogamoogakid
I'm in North Carolina and while we don't really get "cold" - you may have hit it - it has been colder lately. The tire-shine idea sounds like it might work - I'll give it a try. Thanks
Old Feb 10, 2010 | 07:14 AM
strobeyprobey's Avatar
strobeyprobey
I just had mine adjusted at the dealer yesterday. They have bulletins on how to adjust the glass. This was the third or fourth time I have had the roof panels adjusted. If you are still under warranty I would take it to the dealer.
Aug 27, 2015 12:25 PM
Aug 14, 2015 11:13 AM
Aug 14, 2015 11:11 AM
Aug 12, 2015 01:24 PM
