Drivetrain Alta Air filter slippage
Old Feb 8, 2010 | 12:25 PM
that7guy's Avatar
that7guy
I would consider myself mechanically inclined. Ive installed turbo chargers suspension systems, clutches etc. For some odd reason the more I tighten the clamp, the more my Air filter keeps slipping off housing. I'm not sure if I can feel comfortable leaving it on just tight enough for it to stay put.
Old Feb 8, 2010 | 12:27 PM
veggivet's Avatar
veggivet
You may have better luck posting in the Alta feedback forum, as Jared monitors things there on a pretty regular basis.
Old Feb 8, 2010 | 12:31 PM
ECHO-313's Avatar
ECHO-313
I had the same problem.
I cleaned the rubber really good (just the lip that makes contact) and the contact point of the box with degreaser.
No problem after that.
Good luck.
Old Feb 8, 2010 | 07:39 PM
ALTA_Jarid's Avatar
ALTA_Jarid
Good luck.
+1 The oil used on the filters is good stuff! Just clean the rubber extra good and you shouldn't have a problem. If you do let PM me!
Old Feb 8, 2010 | 08:41 PM
that7guy's Avatar
that7guy
Thanks, I'll give it another shot in the AM!
Old Feb 11, 2010 | 11:04 PM
schreiber117's Avatar
schreiber117
I know it's been said, but I had the same problem, called alta, they recomended a good wipe of the inner rubber, I wiped it out, and it hasnt slipped since, for a while, i was popping the hood everytime I parked, to check the intake, hasnt slipped since (now I only pop the hood every 1k or so...)
Aug 27, 2015 03:18 PM
theblackfalcon
Aug 26, 2015 09:18 AM
gkp
Aug 26, 2015 07:18 AM
polotska
Aug 23, 2015 09:10 AM
Aug 21, 2015 08:44 AM
