R50/53 '06 MCS Warranty almost up, what to check?
Old Feb 4, 2010 | 06:14 AM
C-dawg's Avatar
C-dawg
Got about 500 miles left on the clock before the warranty expires. It's an 06 S with a six speed. Any suggestions on thinks I shouls have the MINI check before it's gone?
Old Feb 4, 2010 | 06:27 AM
Helix13mini's Avatar
Helix13mini
Have them check your control arm bushings. If they're not cracked now, they will be in about 600 miles
Old Feb 4, 2010 | 07:19 AM
joelmikel's Avatar
joelmikel
Old Feb 4, 2010 | 07:28 AM
paul_'s Avatar
paul_
Have them check the passenger-side motor mount. Those little buggers give up easier than the heart of a canary...
Old Feb 4, 2010 | 09:22 PM
minjae's Avatar
minjae
wow how weird..i have approx 500 miles till my warranty expires as well!
mine is at the dealer already..stuck with a loaner probably till next week especially cause of the crazy snow we're supposed to be getting.
i just told my dealer all problems, big or small, and what possible things they could check to see if it's because of that part or this part..blah blah
hopefully they fix everything, but with my luck they probably won't.
but honestly i don't think there's much to check, warranty-wise..
besides the typical things people post about failing and wat not.
I say, if anything bothers you even the tiniest bit, let them know! it might fix something else that you had no clue was wrong
Old Feb 5, 2010 | 03:11 AM
Cadenza's Avatar
Cadenza
Mine is up pretty soon too.
Isn't there a TSB for replacing the manual tranny fluid? Might want to do a search.
Ask them to check for sooty residue around the Supercharger's PTO (Waterpump end). If there is residue, oil might be leaking from the PTO gears, which means the S/C is on its way out or the seal between the S/C intake flange and the plastic air hose is leaky.
Here's is what it looks like...
image by courtesy of jblow
Old Feb 5, 2010 | 06:47 AM
thulchatt's Avatar
thulchatt
Probably want to tell them you have a 'problem with...' so they can document and check. Just say you hear sounds or have a problem. If you say you want them to check something they are likely to look, but not really check.
- Power steering pump
- oil pan gasket
- engine mount
- super charger
- control arm bushings
- A/C (hard to have problem in winter but get it charged if you can)
- Get brakes fluid flushed
- Coolant drain and fill (if it is looking brown or discolored)
- Brakes (are they anywhere near the end of the pads)
- Wiper blades
Dec 23, 2015 10:36 AM
Emnotek
Aug 13, 2015 05:47 PM
massmini03
Aug 12, 2015 11:19 AM
clintmeister
Aug 12, 2015 11:11 AM
kwijmbo
Aug 5, 2015 09:00 PM
