Noise when depress clutch
Old Jan 29, 2010 | 12:53 AM
Ralph525's Avatar
Ralph525
Hi, i have a noise when i depress/release the clutch after shifting.
The shifting is fine, no noise at all but when i release the clutch (does not matter if smooth or hard) there is a metalic noise like "clunk". My dealer is not able to fix this problem and i gonna crazy of it.....so is this a normal by MINI or have anybody fix this issue...??
Please help me to get back the Mini-feeling and of course the fun...........
Rgds
Ralph
Sorry: here some details:
Mini Cooper R56
7000km
10/2007
Last edited by Ralph525; Jan 29, 2010 at 01:02 AM. Reason: ...more details........
Old Jan 29, 2010 | 04:03 AM
Flyinace2000's Avatar
Flyinace2000
Mine made a click noise when depressing or releasing. You could feel it in the petal. They replaced some spring and now it feels perfect.
Old Jan 29, 2010 | 10:20 AM
drewstermalloy's Avatar
drewstermalloy
Mine did that until the return spring snapped. The dealer replaced it, and now it's a little better.
Old Jan 30, 2010 | 08:49 AM
Ralph525's Avatar
Ralph525
Hi, thanks for your postings......my problem seems to be more serious.....the noise is also when i accelerate very hard, then brake and accelerate and brake and so on................
Ralph
Old Feb 1, 2010 | 03:35 AM
Ralph525's Avatar
Ralph525
[push up] no one else has this problem ?
Old Feb 12, 2010 | 02:16 PM
GrnMachine11's Avatar
GrnMachine11
My return spring also snapped today. I just called for the part, about $4. I don't have time to sit in line at the dealer repair shop for a few days so I ordered the part and will put it in next week.
I wonder if this is common around 20,000 miles because that is were I am at.
Old Feb 12, 2010 | 05:36 PM
amusingdream's Avatar
amusingdream
I also have a clicking sound when depressing the clutch. I havent noticed any problem associated with the noise yet. I plan on mentioning it at my next service visit.
Old Feb 13, 2010 | 10:20 AM
Ralph525's Avatar
Ralph525
Hi, thanks for the posting....where exactly is this return spring located....?!?!
Old Feb 13, 2010 | 11:31 AM
JAS76's Avatar
JAS76
I just had my mini in the dealership for some funny clutch business. Factory/warranty fix is available.
Jason
Old Feb 14, 2010 | 05:47 AM
Ralph525's Avatar
Ralph525
@JAS78:
can you tell me more details abiut the fixes......the dealers here in Germany are not very bsy to find "my" problem and of course to fix it......they say its normal.......
Old Feb 14, 2010 | 06:02 AM
DrewN's Avatar
DrewN
Ralph, are you hearing a metallic "clunk" when releasing the clutch in 1st? If so I believe that's normal. Try searching "clutch clunk" in these forums - you won't get a direct answer but reading a few random posts it seems that the Getrag can be noisy and this sound is nothing to worry about.
I hear this on occasion. It is intermittent, though, I can never tell when it will happen.
Old Feb 14, 2010 | 06:06 AM
JAS76's Avatar
JAS76
Originally Posted by Ralph525
@JAS78:
I had complained about a noise my clutch was making when engaging and disengaging. They had told me that there was a clutch assembly replacement that Mini had sent out for a fix? Not a recall though from what i understand.
Hope that helps. I can call the service department on Monday and get the full explanation for you if you like.
Jason
Old Feb 15, 2010 | 01:48 AM
Ralph525's Avatar
Ralph525
...I can call the service department on Monday and get the full explanation for you if you like....
that would be great..........
Ralph
Old Feb 15, 2010 | 04:38 PM
GrnMachine11
Set your seat way back and get into the foot well by the clutch and brake with a flash light. Follow the arm of the clutch and there will be a spring (about 1" to 1.5") on the front side of the arm practically behind the dash down there. I'm surprised how flimsy it is for a clutch going in and out. I would say fatigue on the metal set in at 20K miles.
Old Feb 16, 2010 | 01:48 AM
Ralph525's Avatar
Ralph525
Hi, thanks for the explanation.........this is not the problem...... ........the noise is definitly coming from gearbox/clutch......
Old Feb 16, 2010 | 06:52 AM
sequence's Avatar
sequence
Originally Posted by DrewN
Ralph, are you hearing a metallic "clunk" when releasing the clutch in 1st? If so I believe that's normal. Try searching "clutch clunk" in these forums - you won't get a direct answer but reading a few random posts it seems that the Getrag can be noisy and this sound is nothing to worry about..
the clutch on my 05 emitted a lot of weird and scary noises, but never a "clunk" sound when released in first. That does not sound normal to me.
Also, you have your manufacturers mixed up. The tranny is Getrag, while the clutch components and flywheels are made by LuK Gruppe GmbH.
Getrags are generally pretty dependable, but there have been recent BQ issues since Getrag USA's relationship with Chrysler went sour and resulted in bankruptcy.
http://www.autoobserver.com/2008/11/...ankruptcy.html
Now, LuK clutches are a different story, with their spotty-at-best reliability records. You either get a good one or a crappy one, like flipping a coin.
OP my guess is the throwout bearing? They are plastic, and not very durable to begin with.
Old Feb 23, 2010 | 01:27 PM
midge's Avatar
midge
Mine seems to do this as well, however i don't think it's my clutch. When I accelerate in 1st then take my foot off the gas pedal there is an audible clunk, it's the same in 2nd as well, this happens before I put my foot on the clutch pedal.
It only seems to happen after I've actually stopped then moved off!!
Old Feb 24, 2010 | 06:21 AM
Ralph525's Avatar
Ralph525
imho i think its a gearbox-problem....there is a to big tolerance between some gear wheels (may be tooth flank issue)............horrible noise makes me sick........
Old Feb 24, 2010 | 09:18 AM
midge's Avatar
midge
I had my head under the bonnet today and notice at the back of the engine bay behind the airbox, there is a pipe that bends up (coming from the left hand side as you look at it) into a slot at the bulkhead. This pipe has a rectangular end with foam. Now, it had come loose from it's location and seemed to be rattling about, so I plugged it back in and now the clunking sound seems to have stopped. I think that when the engine is under load, the engine ahd been moving and hence the pipe had been moving about creating the noise.
I hope this helps!
ps does anyone know what this pipe is?
Cheers
Old Feb 24, 2010 | 10:19 AM
Ralph525's Avatar
Ralph525
Hi, thanks for your post.......seems to be a pipe from the aircondition or not?
A picture would help......;-)
Old Feb 24, 2010 | 10:30 AM
midge's Avatar
midge
Take a look here, it's item 16 -
http://www.realoem.com/bmw/showparts...06&hg=13&fg=20
Old Feb 24, 2010 | 12:44 PM
Ralph525's Avatar
Ralph525
Hi, unfortunately i do not have a cooper s, only a cooper............no item 16 in my car...........
Old Mar 5, 2010 | 06:05 AM
Ralph525's Avatar
Ralph525
...new idea......could this noise can come from a "bad" suspension ?!?!?............
Old Mar 5, 2010 | 06:25 AM
SSSSSSSS's Avatar
SSSSSSSS
Coordinator :: M2C2
A couple of possibilities come to mind.
A club member recently had a similar clunk that turned out to be a loose front axle nut. It, in fact, came off and left the car motionless. Fortunately not broken but inert.
I was getting a major clunk when shifting into 2nd and found it to be the exhaust hangers were coming out of the bushings allowing the pipe to hit the floorpan.
Old Mar 16, 2010 | 08:12 AM
Ralph525's Avatar
Ralph525
...back from dealer.....
it seems to be fixed.......the dealer changed:
- motor mounting sockets
- shock absorbers (both side) including the spring plates etc...
- shift box (but only the mechanic for shifting)
- driving axles
the reason for the noise is in general a to big tolerance of this parts. This tolerance occured a "movement" from the shock absorvers and the driving axles and making this noise.....
I hope the noise is gone.......in only drove now 2 days........i will report....
Supertractor3
Apr 7, 2017 11:16 AM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Sc00terbum
Sep 11, 2015 07:17 AM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 02:06 PM
