R50/53 Toe Hook Location?
Old Jan 25, 2010 | 03:33 PM
miniwheels's Avatar
miniwheels
Toe Hook Location?
hello, just got a 2006 mini S, love it, where is the toe hook located?
in the glove? battery box area? also where would the sun roof tool be located?
i know car has run flats, any links for a OEM Mini jack? or would a BMW one work?
thanks michael
Old Jan 25, 2010 | 03:46 PM
ZippyNH's Avatar
ZippyNH
Welcome and I hope you love your MINI!!
If you look in the trunk, there should be a foam box next to the battery. in the foam box, there should be a MINI toolkit, the tow hook, and the sunroof crank. As for the Jack....One came with my MINI...even though it came with runflats....sometimes they appear on the Marketplace pretty cheap, or you can get used one from some vendors sometimes...the stock jack is a single sided screw type jack....works pretty well too!!
Sometimes if someone installed a bigger battery than stock, they may have moved the box to the side compartments in the trunk....one side is designed to hold the optional CD changer and satellite radio....the other for an optional roadside emergency/first aid kit that is required in some nations. It could be in either side...I'd take a quick look.
Old Jan 25, 2010 | 05:09 PM
miniwheels's Avatar
miniwheels
found it right in the battery box, how about how to plug in the i-pod cable to the radio, procedure for this, i tryied pullinng down the trap door by steering wheel, need to find out how to remove glove box? the wire is there just can not reach it.
thanks again
anyone have a mini jack or know where to get one? reasonably priced
Old Jan 25, 2010 | 07:05 PM
ZippyNH's Avatar
ZippyNH
I haven't done an i-pod jack/aux jack so I can't help ya there.....if you do a quick search, a how to might pop up.
As for buying a jack....I know WayMotorWorks used to have one shown on their website...used of course....I don't think it is listed anymore, but in my experience, he has lots of stuff not listed, so I bet he could find you one, or at least get you looking in the right direction. I'd shoot them an e-mail, or call them. I really like using them, and have found them to be very good to deal with.
Apr 7, 2020 06:49 PM
vbmike
Oct 15, 2015 04:32 AM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
GregoryK
Sep 10, 2015 10:54 AM
Accessory Products
Sep 9, 2015 10:29 AM
