Navigation & Audio Stereo keeps shutting off
Old Jan 25, 2010 | 01:55 PM
mikeb8134's Avatar
mikeb8134
Hello all,
I installed an amp some months ago (I posted pictures and what not on this site, you can see the install in my history), and have been very happy with my sound system up till about a week or two ago. Since then my stereo just cuts off, (no sound will come out) if I play it any higher than a moderate level. In order to restore the sound I have to turn my car off than on again. The amp seems to be in working order when this takes place (as in there is no warning lights that appear at any time), so I believe the fault to be with my stock head unit. Any ides?
Thanks,
Michael .
Old Jan 25, 2010 | 03:26 PM
miniSQ's Avatar
miniSQ
I owuld guess that somethign in your wiring is wonky, and when you turn it up too loud it over drives the HU. Try this:
Fade your music all the way to the front and then turn it up LOUD.....does it power down? I had a similar situation and it happened while i had a LOC installed and when i had my fade set to the middle. When i was faded mostly to the front i never had the issue. I replaced the LOC with a cleansweep and the problem when away.
Old Jan 26, 2010 | 02:48 PM
mikeb8134's Avatar
mikeb8134
Tried the fade to front. Didn't work.
Any other ideas??
Old Jan 26, 2010 | 04:59 PM
miniSQ's Avatar
miniSQ
check the grounds...or the connections...if it worked perfect for a couple of months and then started acting up it could be a loose wire.
lweaver
Sep 17, 2024 08:22 AM
RobbyD
Jan 29, 2019 01:22 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Norton70
Sep 11, 2015 12:16 PM
