R50/53 That blinking number
Old Jan 23, 2010 | 04:04 PM
scarletswalk's Avatar
scarletswalk
I have a 2003 Zabimaru (his name) Mini, and when I start him up, a little number blinks telling me -2650 miles ago, I should've had my car serviced. Well I just had my oil changed (and my car mostly serviced), and I wanted to know how to reset that little number myself. I swear I will never go to a place to get my oil changed again, as I'm out 75.00 now.
It's annoying me, but a good reminder of when I do need to change the oil and check the filters, etc... Any advice you have would be helpful, thanks in advance!
e and Zabimaru
Old Jan 23, 2010 | 04:48 PM
lhoboy's Avatar
lhoboy
SIA display reset:
- Turn ignition to position 0 (steering lock)
- Press and hold trip reset button, then turn ignition switch to position 1 (steering unlocked). Within 5 seconds dosplay shows current SIA status (OIL SERVICE or INSPECTION),
- Release trip reset button.
- Press and hold trip reset button for 5 seconds to change to reset mode.Display flashes rst.
- Press reset button again. Current service requirement is reset and display shows new status for 5 seconds.
Old Jan 23, 2010 | 04:53 PM
Fatherdeth's Avatar
Fatherdeth
Nice MINI by the way!!
Old Jan 23, 2010 | 10:46 PM
scarletswalk
Thank you both!! This is perfect!!
Old Jan 24, 2010 | 05:44 AM
Capt_bj's Avatar
Capt_bj
the timing of the various press-release seqence' can be a bit persnickity on this....don't be surprised if you end up doing it 4 or 5 times b4 it 'takes'
Old Jan 24, 2010 | 07:52 AM
MINIdave's Avatar
MINIdave
Why do you consider yourself "out" $75? They did change the oil, right?
Do you plan to do it yourself from here on? Cause it's true, it's about $35 if you DIY, but $40 labor in today's market is not bad.....
Alpha Motoring
Sep 7, 2020 07:34 PM
minimofo
Dec 26, 2015 12:03 PM
monkiboy
Oct 16, 2015 09:58 AM
gnhovis
Sep 28, 2015 10:56 AM
daviday
Sep 25, 2015 01:31 AM
