Stock radio won't stay in AUX setting
Old Jan 22, 2010 | 07:07 PM
kevgrn114's Avatar
kevgrn114
I just aquired a 2006 mcsc. When I connect my tomtom iphone car kit to teh AUX connection and start playing music it will play for a bit then switch back to radio. Once this happens I cannot select AUX again unless I unplug my phone and plug it back in.
If I don't have anything connected I can set the radio to AUX and it will stay there indefinately.
Anyone else encounter this behavior?
Thanks,
Kevin
Old Jan 22, 2010 | 07:51 PM
pfriedel's Avatar
pfriedel
My Griffin Autopilot _occasionally_ does this, but I always figured it was because the 12v plug worked its way out of the socket and went dead, and the Mini's stereo detected it as a cold input. I reach down and jam it back into place and it comes back.
Old Jan 22, 2010 | 10:29 PM
CooperSS's Avatar
CooperSS
You probably need a ground loop isolator if this problem only happens when the device is running on power supplied by the car, like a cigarette lighter plug.
Check out this thread, different device but the same problem, many threads on NAM with the same solution.
https://www.northamericanmotoring.com...oop+isola tor
Bill
sevin
May 2, 2026 06:11 AM
surfblue
Oct 24, 2018 01:20 AM
Dashdog
Aug 10, 2015 06:17 AM
tippin
Aug 5, 2015 08:43 AM
