Suspension R56 rear trail arms on R53
Old Jan 19, 2010 | 02:36 PM
Dreammaker's Avatar
Dreammaker
Since i just got a new r56 jcw rear brake kit, i was thinking to replace my rear trail arms with the r56 ones. This way i will loose some weight and i will be able to mount my new brake kit without modifications.
I know people have already done it.
My only concer is if i will face any problem with the suspension. Will it mount on the r56 trailing arm or is there any difference?? I have bilstein pss9 coilovers on my mini.. Si will it be ok??
Please give me any info-help if you can. Thanks
Old Jan 19, 2010 | 03:40 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
To mount your coilovers you'll need these shock bushings.
http://www.waymotorworks.com/r56-rea...ngs-or-gp.html
As for the brakes and such you should be able to mount pretty easy.
Old Jan 20, 2010 | 12:12 AM
Dreammaker's Avatar
Dreammaker
thanks both.. you see i am checking on using spare used rear trail arms.. i do not think i will spend that much! think it would not be good value for money for what i will get on handling! .. so i just need to change the shock bushings and i am ok right?
Old Jan 22, 2010 | 12:41 PM
Dreammaker's Avatar
Dreammaker
.. i have one more question.. since i have bilstein pss9 on my car.. won't it behave differently and feel more harsh with lighter rear traling arms? since the suspension is designed for heavier trailing arms..???
wkp1219
Nov 13, 2015 07:52 AM
Mini'mon
Aug 26, 2015 01:02 PM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
