R55 winter wiper blades
Old Jan 19, 2010 | 01:28 PM
snickers's Avatar
snickers
winter wiper blades
After a couple of days driving in "wintery mix" (the local euphemism for half-frozen crap falling from the sky I'm in the market for winter blades. I bought the Anco Contour blades, but the idiot things don't touch the windshield at the top and bottom 2-3 inches, wiping only the middle band. (The auto parts store won't take these turkeys back because they are "used" )
Any suggestions on a winter blade that will work well on my Clubbie?
Thanks!
Old Jan 20, 2010 | 04:03 AM
schatzy62's Avatar
schatzy62
check this thread over in the coop section as the blades are the same for all second gen cars. There ar a number of suggestions there.
https://www.northamericanmotoring.co...ld-wipers.html
Old Jan 20, 2010 | 08:24 AM
Xeraux's Avatar
Xeraux
They sell these at Costco. They're about US$8.00 each. I put a set on my new Clubman and I really like 'em.
Based on observation, the Goodyear Assurance, the Bosch Icon, Michelin Symphony, and the RainX Latitude, etc are all re-badged versions of the same "bracket-less" blade.
Old Jan 20, 2010 | 09:13 AM
bad venge's Avatar
bad venge
https://www.northamericanmotoring.co...r-options.html
The clubman version ...
I gave up on the rubber encased "winter" blades years ago , WAY too stiff
I've been running the Latitudes for years... I got lucky at the fleamarket they had them for $10 a pair. I bought a case of them ...
I'd highly recomend the Aquapel treatmnt too
Old Feb 9, 2010 | 12:11 PM
snickers's Avatar
snickers
I'm sad to report that the PIAA "Forza Hybrid" winter blades also fail to clean the windscreen. Worse than their less expensive counterparts, the PIAA blades leave a swath in the center of the blade untouched for about half the stroke and then streak the rest of the way across. You wouldn't think it would be so hard to make a wiper blade that actually remains in contact with the window.
Roger
Old Feb 9, 2010 | 03:07 PM
Parkerton's Avatar
Parkerton
I bought these at Costco last week and while the driver side is perfect, the passenger side doesn't come flush with the window in the far right edge resulting in 3-4 inches of sloppy wiping before coming into full contact with the window. They also make a clicking noise with each swipe. They recommend 18 inch for the driver and 19 for the passenger, but I'm wondering if I should've gotten 18 on both.
Old Feb 9, 2010 | 03:08 PM
Parkerton's Avatar
Parkerton
Also, does anyone know what wipers to use for the barn doors? My original wipers are very streaky.
Old Feb 12, 2010 | 04:32 PM
Charva's Avatar
Charva
Wiper blades are free @ the dealer.
Under warranty I believe......
Old Feb 15, 2010 | 05:51 PM
schatzy62's Avatar
schatzy62
Not "Warranty" but "Maintenance Plan"
These are two very different things.
Doc Pain
Mar 10, 2021 04:50 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
freeman727
Dec 10, 2017 04:00 AM
Scm68
Jan 27, 2016 12:33 PM
Samhillrocks
Sep 29, 2015 12:55 PM
